OCTANE BENCHMARK: Submit performance scores for your rig!
ASyme1
BorisGoreta wrote:I'm getting 6.4 on a single TITAN in Octane 1.35. How come ? Are your TITANs overclocked ?
Actually it drops to 5.5 after it warms up.
Hi Boris-
I was using the 1.2 version. I did just download the newest standalone 1.51 and got pretty much exactly the same results though. Yes, I do overclock these with software. Nothing crazy but worth doing as I've never had a problem with them and they seem to run within specs.
So again with 1.51 I'm getting 7.8 and 9.5 in pathtracing with the normal and Black edition.
Alec
Alec Syme
http://www.fuseanimation.com
-Gigabyte X79-UP4 - Intel i7 3930 3.4 - Windows 8.1 Pro 64bit - EVGA TITAN X7 - 32 Gigs Corsair 1600 4 channel RAM -
v-cube
Hello Alec,
can you tell me the name of the breakout box you use? I only found some for 4 PCI express cards...
thank you in advance
Andreas
1 x 4090 GTX, 1 x 3090 GTX
http://www.v-cube.de
ASyme1
v-cube wrote:Hello Alec,
Andreas
Sure. It's Netstor. It's also a 4 cards unit. Together with the three left in the computer you end up with seven. (That last bottom slot connects the chassis to the computer so it can't hold an eighth card.
alec
Alec Syme
v-cube
OK -> yes of course... 3 + 4 stupid me... now i got it thanks
Andreas
smicha
Hi Boris-
Alec
I also get about 6.4 on TITAN and 8.2 on heavily overclocked (+200core, +500mem) v1.52. So 7.8 might be due to some changes in the camera settings - any slight change will affect the score. So to compare results we must be sure that we are using exactly the same settings.
BorisGoreta
But what values do you guys get after you let it cook for a minute or so ? I thought
Overclockong titans doesnt matter because it downclocks itself as soon as it
gets a little bit hotter which is pretty quick.
smicha
Boris,
My TITAN is watercooled on EK XXL and never exceeds 45C overclocked. So 8.2 is stable. Overclocking gives me at least 20% more speed.
ASyme1
BorisGoreta wrote:But what values do you guys get after you let it cook for a minute or so ? I thought
Well I turned the samples up to 3000 and let it go almost three minutes with barely any loss is speed. Went from 9.5 to 9.45. Doesn't seem to be a problem.
Alec
Alec Syme
smicha
Alec,
could you upload as attachment the scene?
BorisGoreta
And they are stock air cooled ?
What software do you use to overclock ?
I have downloaded Asus GPU Tweak but it only overclocks 2 GPUs for some reason.
