Cinema4D version 2020.1.5-R4 (Obsolete stable) 17.10.2020
Weezer
We were told to stick with R21 for the time being, so, no, it won't work in R23 (let alone S22). It'll happen, but since Octane X PR2 is just around the corner, it maybe makes sense to bring it all together with the latest version. It's annoying, but this stuff takes time and Maxon keeps on moving the goal posts every six months.
FelipeCortes
I find that looking inside cinema is a good addition, sometimes you need to see approximately what the composer will see in the end, or in advertising, sometimes you need to work so fast and you go back and forth so much that you have to go to after effects to add a simple effect and re-rendering is a punishment. Anyway, magic bullet looks is a post-effect, so cinema adds it to the render after going through whatever render engine it is.
SSmolak
Yes, Magic Bullet is a post and it filtering viewports so you can see it live but most probably it will not be visible in Octane LiveViewer even in viewport mode.
wrapthereal66
hello ! i'm coming back to you with my first test with my 3080 and ... it crash ! :/
i use the driver 456.16 that nvidia send me ! and my 3080 appear in the device pannel in octane, but it crash !
i attach you a bugreport !
_BugReport.txt
(971.98 KiB) Downloaded 366 times
wrapthereal66
so i can't make any render with this drivers !
wrapthereal66
i manage to start a render, but its crash just after the launch !
this is the log :
Started logging on 09.09.20 23:18:55
OctaneRender Enterprise 2020.1.5 (8010500)
CUDA error 719 on device 0: unspecified launch failure
-> failed to copy pitched memory from device
-> failed to launch kernel(kernel37)
device 0: path tracing kernel failed
-> failed to deallocate device memory
-> could not get memory info
-> failed to copy memory to device.
device 0: failed to upload data texture 17 '0:__data15__'
wrapthereal66
hello ! i fresh install the drivers , but my 3080 don't appear in the device pannel in the kernel now ! :/
wrapthereal66
just for information , i need to release my test on monday ! ahah so maybe there won't be the fix by then and I won't be able to show the performances on octane! it would be a shame! :(
bassruettler
Hi, i like the new zoom feature.
However, this seems to have replaced the gizmo where you could zoom in on an area and get a color value read-out.
Is that gone for good now or has that moved to another shortcut?
