Cinema 4D version 4.04-R2 (Obsolete stable) 06.05.2019
3dworks wrote:i am having an issue with live viewer and i can reproduce this in all my complex scenes.
when a scene is loaded in C4D and i start the live viewer the first time, data will be transferrend very fast to the engine, only a few non-octane materials in the scene are converted. if i stop and restart that preview render (also after i closed and reopened the lve viewer window), and start a preview, octane will take a much longer time to send all the data to the engine. i also can see that status will report a material conversion for ALL the used materials in the scene. in many cases it goes from a few sconds to nearly a minute! is this a known bug or could it be some setting which causes this?
C4D prime R20 V20.059 mac / macpro 5,1 48G RAM, nvidia 980ti 6G VRAM, mac os 10.13.6
I didn't see this kind of behavior. Are you talking about a specific scene?
3dworks
i'm experiancing it with all my scenes so far. should i send you the file? will logs help?
Logs will show the times of render processes. Activate all log options and Send me c4doctanelog.txt after render operations.
3dworks
aoktar wrote:Logs will show the times of render processes. Activate all log options and Send me c4doctanelog.txt after render operations.
OK i will get back to you soon! thank you markus
EDIT: i forgot to mention this is only with live viewer, apparently no issues when rendering to picture viewer!
GSMATTAnimation
I am having a problem with closing Cinema R20.059, when I close Cinema 4D it makes the application hang and not responsive.
I the have to close Cinema via the task manager. Anyone else having this problem?
GSMATTAnimation wrote:I am having a problem with closing Cinema R20.059, when I close Cinema 4D it makes the application hang and not responsive.
Activate all log flags for scene and close C4D. Then send me c4doctanelog.txt.
GSMATTAnimation
Just to confirm that is in Octane Settings > Settings > Other > Log Output, then tick all what is available?
I have notice when closing it leaves a message at the bottom left of Cinema saying "Octane:closeAll()"
Not to sure if that helps you at all?
Yes tick all. Then exit and grab the log file and send me. Other than this try without other plugins loaded.
VVG
aoktar wrote:.
Hi, when should we wait for Octane 2019 XB2 for tests?
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
stefano-dear
In the last days I have a lot of shutdowns when denoiser start with the complete render.
I have tried a lot with different driver but nothing change... The strange thing its that happen also with small scene that don't use a lot of memory.
I haven't any crash log because the computer shuts down! Absolutely frustrating!!!
MAC 10.13.6 + GTX 1080Ti - Driver NVIDIA 410.130
SLAVE Win 10 + 3x GTX 1080Ti + 2x GTX 980Ti - Driver NVIDIA 419.67
C4D R20.059
OSX panic report.doc
(38 KiB) Downloaded 418 times
