OctaneRender 4 for Modo [OBSOLETE]
I have posted the next Octane 2018.1 build at viewtopic.php?f=34&t=71026. If there are future Octane 4 builds, they will still be posted in this thread.
MrFurious
Hi Paul I think there might be a bug with the latest Octane 4 plugin 4.02.1.140. When using the panorama camera I can't seem to disable DOF.
Dino Inglese
CG Artist
Melbourne Australia
Octane build 4.04.0.145
Can you provide some more info on this please? I just set the Aperture to 0 and the Panoramic render did ot render with DOF.
MrFurious
Your right.. I can control this through the imager: focal depth and aperture. I was using the modo camera DOF controls and they seem to not work with panoramic camera.
Dino.
Dino Inglese
CG Artist
Melbourne Australia
MrFurious
Will the octane V4 plugin be available for current (and possibly future) Modo releases ie: Modo 13?
Dino Inglese
CG Artist
Melbourne Australia
The plugin should already work on Modo13. Unsure when Modo14 is planned, but I will probably do an Octane 4 build for it too assuming the base plugin code has not changed too much.
Buttercup
Hello! Tell me where I can download the plugin to build 4.01 - (4.01.138)
Thanks for help!
That version has been superceded by the releases at the top of this thread. Are these releases not working for you?
Buttercup
4.02.0.139-4.02.140 gives CUDA 700 error. Thank you, I found 4.01.0.138 in my old backup. But that didn't solve my problem. In my Visualizer, a black dot appears in the center of the frame. And I can't delete it. I think this is due to the camera when the point in the frame has Full HD resolution, it is smaller and the Denoiser almost handles it
https://www.dropbox.com/s/fro40nknfmah3 ... 0.png?dl=0
https://www.dropbox.com/s/5vz1icyox8esm ... 6.png?dl=0
Buttercup
It does not depend on the project . When you create a new one, the effect is repeated.
Maybe the modo camera is collapsing. Solved the problem of enabling DOF octane + autofocus
Return to “Foundry Modo”
