Version 4.0- XB4-test1 (Experimental)
shine71
Hi Ahmet!
First of all, thanks as always for your great work, then, I'm not sure if this issue has been outlined yet.
In last version (XB4) I met some issue with post processing, both bloom than glare, working in live viewer.
If I set values that could work, once render finished and I apply denoiser, they are almost disappearing, so I need to increase values for both of them to have effects back.
This thing worked good in previous one, but actaully not.
Thanks again and have a great day!
rleuchovius
Hi!
The Render passes Compression for EXR does not seem to work, I've tried multiple versions of octane from 3.08 to 4 and there is no difference in size between the none setting and any of the other compression settings.
The compression of the Main picture work fine though.
aybekdes
aoktar wrote:
GillesKontrol wrote: Path tracing to info channels is a bug I have all the time as well. !
I've finally found the issue and fixed. I'll make a new build for you.
Please can you apply this fix to the stable release also?
rleuchovius wrote:Hi!
It's a C4D SDK problem. I had some talk to Maxon guys about that and compression parameter is not working well.
antonbohlin wrote:Hello all! I'm having lots of issues with this version, mainly with render settings being switched to Infochannels randomly plus in general the settings are being reset constantly. Can I save new default render settings? Also seems like the denoiser doesn't work for me, if I try to render to PV it doesn't save the frames if I have denoiser enabled. The new viewport mode is great, but it makes my C4D GUI very unstable and flickering, so I can't really use it for long.
You should enable denoising device. It's not saving selections. Infochannel fix is ready.
Cheiser
4.0 RC1 please?)
Yan
Cheiser wrote:4.0 RC1 please?)
Yees. Please please :)
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, 4x EVGA GTX 1080Ti, Octane-for-C4D 4.x.x, Nvidia 398.82
Studio21
Yes, RC 1 would be great :)
I'll make it asap. Now I'm building 3.08.3.
Cheiser
So we are going to 4.0 or still stay on 3.08? Is 4.0 stable or another "experimental" standalone build?
