OctaneRender® for 3ds max® v4.00-XB3 - 6.01 [TEST][OBSOLETE]
richardyarlett
Quick question...
If NETWORK RENDERING is currently disabled, what about the ORC ? If I buy an ORC subscription, does the ORC currently support this v4.00-XB3 build, or will it only work with the official commercial releases like 3.08 ?
acc24ex
old bug: try this shift move (copy) a moveable proxy/instance - and it's not longer moveable - have to restart viewport - renderable on off works now ..
..and I noticed that you fixed when you delete an object the viewport doesn't self unpause - nice
..BTW most all the options in the postprocessing don't restart the render, only aperture - and now AI denoiser - maybe put those in the same group - kind of a UX thing approach -
paride4331
richardyarlett wrote:Quick question...
Hi richardyarlett,
viewtopic.php?f=80&t=67834
This is a TEST release with new features implemented, so some issues are expected. Please report the bugs in the "Bug reports" section.
Please note that this release is based on Octane V4 XB3, and is not recommended for production work :
As with all experimental and test releases, please do not use this build for production work, and please note that we still classify this as an experimental release. We cannot guarantee that scenes saved with this version would be compatible with future releases.
viewtopic.php?f=33&t=67790
ORC is 3.08x SDK based.
Regards
Paride
coilbook
Hi otoy
Since there is no good solution for processing phoenix fd ocean mesh each frame, is octane 4 going to solve this problem? Thanks
acc24ex
..so apparently I'm using this for production (I know), and it's working fine.. bugs fixed from before .. only that shift copy of instance doesn't behave..
- same thing with make unique - it doesn't octane viewport still thinks it's an instance, but the 3dmax viewport behaves as it should - so check on make unique and copying of instanced moveable proxies (copying as in make a copy of and instance, not copy instance to instance)
.. and yeah, pretty stable, denoiser seems to do it's thing, feels like I've almost added another gpu
nildoe
i asked in the standalone forum, but didnt get a reply, can anyone tell me if offline license has been RE-implemented ?
Nildo
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
paride4331
nildoe wrote:i asked in the standalone forum, but didnt get a reply, can anyone tell me if offline license has been RE-implemented ?
Nildo
Hi Nildoe.
viewtopic.php?f=24&t=67352&p=340551&hil ... ne#p340551
Regards
Paride
nildoe
Thanks Paride..I had posted my question in the 4.0 topic...
so its my understanding that offline mode is now working but still not very stable and developers are advising that we stick with 3.07 yes?
Nildo
paride4331
Hi Nildoe,
we are talking about development, it has not yet integrated into V 3.08 or V4
if you need offline, mode 3.07 it's the only solution.
Regards
Paride
wisemanxxx
I'm trying this version for a couple of days. Generally it's very fast and works stable for me. BUT; I guess there is a big problem with Forest Pack plugin. Because if there are some forest objects in scene 3ds Max crashes very often. Changing environment texture, entering material editor, importing an object to scene, trying to switch to CLAY mode.. everything causes an instant crash. I try same scene without Forest objects. There is no big problem without them.Rarely crashes..
This may caused by Forest or VRAM.I have 2 1080TI for rendering and scene takes 6.9GB in vram. Denoiser GPU is 780 TI..
