Thank you! octane rocks as alwaysGoldorak wrote:We'll have an update on this at GTC17 next week. We have the Brigade real time denoiser work (at minimum will be in V4), but also developing an experimental offline (but fast) denoiser in R&D for OctaneImager SDK which we can test in V3 versions once the Image/module SDK is ready. There will also be support for 3rd party denoisers through the same API, but we're at the point where we think we can contribute something new to this areas and want to build it in as a 1st party feature as soon as it's ready.
OctaneRender™ Standalone 3.06
Hi Can you, guys, add procedural flakes shader to the noise for metallic paints and sparkles for snow. we tried with small noise like circles, chips and it just does not work.
Also will we see more procedural textures in the future?
vray flakes https://docs.chaosgroup.com/display/VRA ... yFlakesMtl
Goldorak wrote:VRay flakes OSL does in fact work in 3.10:
https://www.facebook.com/groups/OctaneR ... 008125513/
thanks! Looking forward to 3.10 soon and more native OSL octane procedural textures too
we only have vray demo hopefully it will work
- Elvissuperstar007
- Contact:
Please add the ability to render such pre-rendered, Only not lua. We can not use lua in integrations
We do not have 8-12GB video cards. Some memory blocks windows
description
Have you ever had a client asking you for a huge print? A rendering with dimensions bigger than 32768 pixels? Have you ever tried to set a size like this in the render ouput of Autodesk® 3ds Max®? SliceRender bypasses these limitations and handles the limits of 30000 pixels that JPG and Adobe Photoshop© have! Our plugin slices your big rendering in small parts and stitches them together afterwards. The rendered strips/slices/crops/buckets don't break the maximum of 30000 pixels in width or height so you can easily edit them in your favorite image editing software or give them directly to the printing company of your choice. You can also use SliceRender for panorama walls, video walls, photographic wallpaper,...
You have the fun, we slice your render!
description
Elvis - I don't understand, what is it you want to pre-render? You will be able to render into a texture in 3.07 and feed the baked results back into the the node system:
viewtopic.php?p=312950#p312950
- andrey.krivulya
- Contact:
Goldorak, we need this feature like a slicer. For example - Octane can't render 50 000 * 28 125 resolution,
but with this feature in camera or in render settings - we will create virtual box, which will separate this resolution on a few parts.
Then when Octane will render all parts - in result we will have all image with 50 000 * 28 125 ( 12 parts like in previous image) , like as you will glue all parts together in the Photoshop...
Vray have this feature... And during render this parts - it make one final image.
Can you add this feature? And Did you understand what we mean? =)))
I hope we will have this feature soon, because many clients want to render this big resolutions for banners and etc... and Vray can help with this.. BUT =) We like Octane and want this feature in Octane Render =) Because it very fast =)
P.S. But please, don't create lut scripts. Because many people which use OCtane Standalone, made many cool features for OCtane with lut... But we can't use lut in Octane for 3dsmax.
Best regards, Andrew.
Windows 11 Pro / Intel Core Ultra 9 285HX / 96GB DDR5 / RTX 5090 Laptop 24GB / 4TB SSD / MSI Titan 18 HX AI
My youtube channel with 3d tutorials ----- >>>> https://www.youtube.com/c/AndrewKrivulya
- RoboticOmen
Please help where is my sphere in the Render View port ? I spent 300 dollars I don't want it to go to waste.
http://sta.sh/022s7w7g2n5y
