OctaneRender™ Standalone 3.03.3
frankjrmi
bepeg4d wrote:Hi frankjrmi,
have a look at this other discussion in the Apple MacOs section:
viewtopic.php?f=14&t=56333
Thanks Beppe. I rolled back to El Capitan and am having the same issues. Here is the dialogue information I'm getting defining the error. Any of this make sense to you?
Process: octane [5650]
Path: /Applications/OctaneRender 3.03.3.app/Contents/MacOS/octane
Identifier: com.otoy.octanerender
Version: ???
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: octane [5650]
User ID: 501
Date/Time: 2016-09-26 15:47:47.522 -0400
OS Version: Mac OS X 10.11.6 (15G31)
Report Version: 11
Anonymous UUID: 8AE1B36B-286E-88F4-2940-102F98A2A95B
Time Awake Since Boot: 4200 seconds
System Integrity Protection: enabled
Crashed Thread: 0
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: @rpath/CUDA.framework/Versions/A/CUDA
Referenced from: /Applications/OctaneRender 3.03.3.app/Contents/MacOS/octane
Reason: image not found
Binary Images:
0x7fff6a210000 - 0x7fff6a247a47 dyld (360.22) <DC81CC9D-651A-3A45-8809-928282052BD3> /usr/lib/dyld
0x7fff9dec7000 - 0x7fff9dec7fff com.apple.Carbon (154 - 157) <8F6ED602-5943-3E29-A793-BC331E2C183D> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
Model: MacPro6,1, BootROM MP61.0116.B17, 12 processors, 12-Core Intel Xeon E5, 2.7 GHz, 64 GB, SMC 2.20f18
Graphics: AMD FirePro D700, AMD FirePro D700, PCIe, 6144 MB
Memory Module: DIMM1, 16 GB, DDR3 ECC, 1866 MHz, 0x80AD, 0x484D54343247523742465234432D52442020
Memory Module: DIMM2, 16 GB, DDR3 ECC, 1866 MHz, 0x80AD, 0x484D54343247523742465234432D52442020
Memory Module: DIMM3, 16 GB, DDR3 ECC, 1866 MHz, 0x80AD, 0x484D54343247523742465234432D52442020
Memory Module: DIMM4, 16 GB, DDR3 ECC, 1866 MHz, 0x80AD, 0x484D54343247523742465234432D52442020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x135), Broadcom BCM43xx 1.0 (7.21.95.175.1a6)
Bluetooth: Version 4.4.6f1 17910, 3 services, 27 devices, 1 incoming serial ports
Network Service: Ethernet 1, Ethernet, en0
PCI Card: AMD FirePro D700, Display Controller, Slot-1
PCI Card: AMD FirePro D700, Display Controller, Slot-2
Serial ATA Device: APPLE SSD SM0512G, 500.28 GB
USB Device: USB 2.0 Bus
USB Device: Hub
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: USB 3.0 Bus
USB Device: USB3.0 Hub
USB Device: Hub
USB Device: Keyboard Hub
USB Device: Apple Keyboard
USB Device: Apple LED Cinema Display
USB Device: Display iSight
USB Device: Display Audio
USB Device: USB2.0 Hub
Thunderbolt Bus: Mac Pro, Apple Inc., 19.2
Hi frankjrmi,
did you check your CUDA drivers?
Dyld Error Message:
http://www.nvidia.com/object/mac-driver-archive.html
frankjrmi
Dyld Error Message:
I have dual AMD FirePro D700 cards, which I don't think support CUDA. :/
We do, however, have a render slave with dual NVIDIA Titan Black cards, so I would hope that even though my local computer doesn't support CUDA, I could at least use the render slave while I'm working. The problem I that I can't even install Octane on my local computer, for some strange reason. Shouldn't I at least be able to install even without CUDA support locally?
Hi frankjrmi,
yes correct, your dual AMD are not supported, since Octane is a CUDA application and needs one or more Nvidia gpus. But you can add one or more to you system via Thunderbolt port and E-GPU solutions.
In this way you can use the dual AMD for the system and drawing while the Nvidia GPUs work for Octane only.
There some users with Mac Pro like yours and this solution here on the forum. You could start from this long discussion:
viewtopic.php?f=9&t=43439&start=170#p276341
frankjrmi
Thank you. Not the news I wanted to hear, but at least there is an option. I appreciate your help.
frankjrmi
Hi bepeg4d,
So, I've been researching this issue, and what about Otoy's announcement that Octane 3 would support OpenCL cards like AMD? Does Octane 3 support OpenCL or not, and if not, any idea when that support is coming?
https://home.otoy.com/otoy-unveils-octa ... -renderer/
Hi frankjrmi,
no sorry, no OpenCL support in v3. That announcement is quite old, now there is a new road map:
https://home.otoy.com/octanerender-3-an ... ap-update/
ura
I connect a license for home and business machine. Always online turn. Why license was suspended?
ura
ura wrote:I connect a license for home and business machine. Always online turn. Why license was suspended?
Found. I activated the license for the second version of the second working machine. It is not allowed to run either version 2 or version 3.
Why are they linked?
I thought that I have version 2 and version 3 are independently from each other?
Hi ura,
the authentication system has completely renewed and now you only need to close OctaneRender to free up a v3 license. V2 is different and you have to sign-out from within the plugin and Standalone in the Account section to free up the v2 license.
On your OctaneLive page you can monitoring where and what kind of license is active or not, and deactivate accordingly.
Here you can find a more detailed explanation about the new authentication system and his new features:
https://docs.otoy.com/manuals/products/ ... et-access/
