Version 2.26.1 (28.11.2016) - Obsolete Stable
Huv
Regarding this post : viewtopic.php?f=30&t=52551
Aoktar, could be confirm it is not yet implanted ?
Thanks ;)
Huv wrote:Regarding this post : viewtopic.php?f=30&t=52551
Thanks ;)
Not implemented. It's not practically possible to implement this with current features of Octane.
Huv
:cry:
Any chance to have the "random color" shader of octane more powerful ? (to have a kind of "variation shader" look like...)
Thanks for your answer anyway ;)
Huv wrote::cry:
It's not a plugin job/possibility to implement a current shader. Theoretically some ways are possible to do just by plugin implementations, but these are not fast and powerful solutions. This can cause extra criticisms rather than getting some appreciations.
I hope this makes some sense. Ex. mograph colors are a kind of implementation. So we should see V3 and next features.
Huv
Ok, i'll have to wait and manage with the actual random color shader ;)
martinzip
Hello Ahmet
thank at first for your great work on the octane renderer !!
I have a problem concerning rendering out Multipasses with the teamrender.
Can you please give a short sketch of the workflow with teamrenderer?
Thanks in advance for your help.
borzoff
Wrong save "render layer id" and "Material Id" and "Object ID".
save when should record each color in a separate channel for EXR and RPF formats. then it will be normal to choose a mask when using ID MATTE IDentifier and in the after-effect.
And if there is a render with motionBlur impossible to mask the object.
correct Please greatly complicates the work.
And if we consider separately the mask using this piece here
https://yadi.sk/i/_YtDDY4bojGo6
a motion blur is not on the masks.
borzoff wrote:Wrong save "render layer id" and "Material Id" and "Object ID".
To activate the "distributed pathtracing" is required for motion blur effects.
zoppo
I can't get the Z-Depth pass to render properly:
This happens in the LV when rendering with PT but choosing Z:
Still the same when changing to zdepth and Infochannels. Z-depth max is ignored:
When swithing to "Main" it works:
My problem: when rendering in the Picture Viewer with the settings in the first picture the z-depth pass that is saved is the wrong one (picture 2 and 3).
The only way I found to get the correct pass (as in the last picture) is to set the Octane Settings to Infochannels (like in picture 3 and 4).
But obviously I won't get a Beauty Pass this way, because the Z-Depth pass is rendered as a beauty pass (main pass).
C4D 2025 | Win10
borzoff
Thank you very much for this tip, I'll try.
but here's the problem with the EXR format recording and Object ID and Material ID is still there. I want to bring one pass, rather than a bunch of masks. Probably expect a fix for this problem.
https://yadi.sk/d/FuN4XU2conkMo
https://yadi.sk/d/lxSGSl0-onkBq
https://yadi.sk/d/Noi6dBmWonjbN
