Hydra wrote:Just a thought, but you are planning to build a room/chamber for putting your PCs in, right?
right
Hydra wrote:Have you considered getting rid of the cases all together? It seems that a lot of what PCs do is use fans to move air (often poorly) in a tight space to improve circulation. In the open fans, and pumps would be louder, but you could work on making the chamber silent. However working on and playing with your water systems would be much much easier.
http://www.dimastechcooling.it/en
What I want to try, when CoolBox will be ready, is to remove the panels of the cases and see if the airflow will improve or worsen. I thought in general the airflow gets worse when open the case, because of disturbing the airflow and cause turbulences unwanted.
I tried removing the side panel with the 780T (another thread) case and it unexpectedly improved performance.
Ofcourse it says nothing about other cases and also depends on the ambient airflow.
So... I am looking forward to experiment when Coolbox is ready and have a airflow with airco
Hydra wrote:I have another question about all this. What will you gain in terms of performance? Could you make that up by not going with the water cooling, and upgrading your older machines with, say, Titan X's?
I am not only doing this for performance gain on short term but I want to get ready for performance gain in future.
I got some numbers (i.e. Smicha) that watercookling would give 30-35% performance improvement.
So with watercooling triple Titan Z they will perform like 4 Titan Z on air.
For me that is a good investment reason to stick these cards on a 6-slot mobo in a beauty open case, and I can not do that better with other cards. This way this build transforms from 2x Titan Z on air to 3 Titan Z wtercooled, and that is a hack of improvement! And triple Titan Z is still unbeatable by quad X, right?
This way this build imo gives maximum performance possible for 3card setup in this 780T build.
Doing it this way it gives my other builds (in bigger cases with more slots) room for adding another card (that is on the shelf now
) to match up the 12 GPU limit in networkrendering.
For future performance upgrade I have in mind to wait a while and when new generation card (Pascal?) comes out I might swap triple 780Ti (3gb) card with triple new ones on air... or even quad on water if my experience with wc is more experienced then, and budget allows it ofcouse
So, this is more for long term, and also gets me into watercooling, which is fun...
and which is scary road for me too, to walk on as newbee...
but let fun prevale
greetz,
