Lua script for texture animation?
Forum for OctaneRender Lua scripting examples, discussion and support.
Refracty
Thank you Grimm
glimpse
wow, I just thought about idea of animated HDR backgrounds/skies..& remembered I've seen a thread on forums about animated textures..
curious how it is going on? is it possible? what are the limitations & so on =) it would be so awesome to have this feature! =)
grimm
The script should still work with the new version, if it doesn't let me know. Here is another little test video I did with two animated textures, a hdri and a movie, running at the same time. The animation is controlled with an Alembic file.
jtmsf
Did a search in google for an animated texture solution for octane and discovered this script. Absolutely fantastic!! Thank You!!
Moonhowl
Many thanks mr. Grimm, you just saved my life. Well, figuratively speaking at least.
Perhaps this will help someone though:
I have a 2500 frame animation and two separate texture sequences, each only 150 frames long, one starts at 400 and finishes at 550 and the other one at 1300 and then finishes at 1450.
So obviously this was an issue as the script by default just starts at frame 0 of the animation itself + annoys with "missing rgb for frame xxxx" for the other 2350 frames.
So I just populated the rest of the frames with either the first or the last frame of the texture animation (so that I had 2500 frames total) and used batch renamer to accurately place the texture sequence with the rest of the frames where it belonged (say, the actual 150 frame texture sequence would start at frame 400, whereas previous 399 frames would be just the same texture from the sequence, the very first one - vice versa on the other end to 2500).
Hope this helps someone.
Asus V Extreme motherboard, i7-5930K CPU, 32 GB DDR4 Quad Channel RAM, 3x Nvidia Geforce 1080ti, Windows 7 Ultimate 64, 3DS Max 2019 64
prehabitat
Any word from OTOY if this can be checked/polished/vetted and added to the next release?
Win10/3770/16gb/K600(display)/GTX780(Octane)/GTX590/372.70
Octane 3.x: GH Lands VARQ Rhino5 -Rhino.io- C4D R16 / Revit17
grimm
Thanks guys, I had plans on upgrading the script to allow you to choose when to start the animation, etc. Thomas (or maybe Roeland) did say that they will have animated textures in 3.0 so I haven't updated the script.
I can't see the embedded vimeo videos anymore, did something change on the site?
abstrax
prehabitat wrote:Any word from OTOY if this can be checked/polished/vetted and added to the next release?
We will support animated textures natively in version 3, i.e. we don't plan to improve this script graph or include it in Octane.
prehabitat
Great news, thanks! :)
lalaku
grimm wrote:Here you go: :D
anim_texture.lua
Darling grimm,about "anim_texture",How do I use it?Do you have a video tutorial?Thanks very much!
Return to “Lua Scripting”
