OctaneRender for Carrara 2.10.0053 [Test]
Wow, Thanks Sighman!
http://www.Neil-Isted.com
Intel i7 870/2.93 GHz
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
OctaneRender™ for Blender
Ds pro
OR Standalone V4
Poser Plugin
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
Ds pro
OR Standalone V4
Poser Plugin
That's great Sighman! Several users (including me!) have noticed that HowieFarkes scenes are slower to interact in 8.5 than in 8.1 - could the reason be connected with the Assembly Room loading hi-res trees, and was it an influence of the OR4C plugin, or is that still a separate issue. I'll do some tests but thought you view would be useful.
Well I got so far breaking it down but basically the scene won't import into a fresh scene, even bit by bit. Something is amiss with the scene it would appear so I've hit a dead end and will have to use one of the alternatives outlined above. Perhaps in the future someone else gets this issue and the diagnostics from that scene will shed some light on this issue.SciFiFunk wrote:I will try to construct the scene from scratch by merging in elements to a brand new scene, bit by bit until it goes wrong again. I'd like this fixed because I've seen the correct frame (with the background and how it colours the internal scene), and it's more life like. I'll try that and any other suggestion you have tomorrow and get back to you.
That is exactly the reason I have added the switch. I don't know why 8.5 is so much slower that 8.1 but this switch should address this issue. The only alternative was to uninstall the plugin.PhilW wrote:That's great Sighman! Several users (including me!) have noticed that HowieFarkes scenes are slower to interact in 8.5 than in 8.1 - could the reason be connected with the Assembly Room loading hi-res trees, and was it an influence of the OR4C plugin, or is that still a separate issue. I'll do some tests but thought you view would be useful.
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
I'm up and rendering again.
Used an infinite plane in the distance, stretched it to size and make window glass transparent to avoid unwanted bounce off of the plane. Not ideal but workable.
re: New features. Can't wait to try out those render passes. That's a potentially huge saving in render time. I'll get back to you on that. Nice one!
re: Switching camera. Works first time, but after a few switches I'm getting the render camera (in the render room), not the one I've selected. I can give more on this if you need it.
All heading in the right direction though!
I'll spend a little time this weekend adding some diagnostics that might help me track down this issue.SciFiFunk wrote:Well I got so far breaking it down but basically the scene won't import into a fresh scene, even bit by bit. Something is amiss with the scene it would appear so I've hit a dead end and will have to use one of the alternatives outlined above. Perhaps in the future someone else gets this issue and the diagnostics from that scene will shed some light on this issue.SciFiFunk wrote:I will try to construct the scene from scratch by merging in elements to a brand new scene, bit by bit until it goes wrong again. I'd like this fixed because I've seen the correct frame (with the background and how it colours the internal scene), and it's more life like. I'll try that and any other suggestion you have tomorrow and get back to you.
Orion_uk has also reported camera selection issues. I'll try and track that one down too.
Another little bug (i think I mentioned it before but if you are looking at stuff this weekend..)
The filename prefix within the Animation tab is still not saved with the scene. I think I read that this was fixed. Certainly the Render target settings that I've used are being stored in the scene, which is a great improvement.
Thanks.
Thanks.
Hi Sighman,
Can't post screen shot until I get home (but no real need as you have seen it a few times before) but the 'blue/white issue' when clicking in RTS is back again! Just thought you may want to know
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
Ds pro
OR Standalone V4
Poser Plugin
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
Ds pro
OR Standalone V4
Poser Plugin
