Ok, that is odd. The whole behavior thing you describe is astonishing to me. I checked and the events that are necessary to switch the scene when you change rooms or jump in/out just don't happen for me. Do you remember which version you were using when it did work?Tugpsx wrote: I did try that before posting and OVP did not update as it did before. So something is different. I did notice that when you switch to modeler room from main that the OVP updated on the previous, it also worked for "Jump In". Some thing was triggering a change and the OVP would update. I guess its ok because some may not want that to happen. I do like the ability to work on the model and then return to the main room to see the results.
As far as modelling, the ORVP is updating for me in both the vertex and spline editor. This is going to be another 'issue' that will have to wait a bit.
