OctaneRender® for Poser (Mac OS X) 2.24.2 [TEST]
Victor2112
I think I may have lost track of this post. Is the Plug-in for Poser 10 still being worked on? I tried some of the current links and it looks like they are for Poser 2014. Sorry to be a pest about this, but I'm very anxious to try the plug-in for Poser 10. :)
Evolutionary
Victor2112 wrote:I think I may have lost track of this post. Is the Plug-in for Poser 10 still being worked on? I tried some of the current links and it looks like they are for Poser 2014. Sorry to be a pest about this, but I'm very anxious to try the plug-in for Poser 10. :)
I ended up upgrading to poser pro 2014 from 10 as they halved the price this week.
Evolutionary
Hi Paul,
Found another issue (on top of the dialog for material import not working) on 2.10
Right clicking and selecting delete all nodes referencing ..... fails due to looking for windows based paths not OSX.
Thanks for your efforts Paul
Yes - still being worked on. There is a problem with Poser 10 displaying the plugin setup window - which has been reported to Smith Micro - and they are looking into it. Sorry - there is no ETA on a resolution at this point.
Can you pls delete your config.xml file - it will be in the Poser references folder, which you can determine by opening a Python Shell in Poser and typing poser.PrefsLocation(). This may rectify the problem.
I cannot find a "delete all nodes referencing" command in the plugin. Can you tell me the exact rightclick menu command causing this pls?
Evolutionary
Hi Paul,
Deleted the config.xml file, didn't make a difference.
The import material option doesn't open a dialog
If you right click on any texture map the option Delete all nodes referencing map name then the following message is displayed in the Main Wacros
Traceback (most recent call last):
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\SetupForm.py", line 2090, in MenuSelectionCb
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\MaterialManager.py", line 1603, in DeleteAllReferencesToImageFile
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\MaterialManager.py", line 1621, in deleteImageFile
KeyError: <OctaneRender for Poser.Node.Node instance at 0x11001eea8>
Evolutionary
Oh and Otoy must have fixed the LiveDB name as all categories are working fine with the plugin. In fact - so far it's been rock solid with not one single crash with my testing tonight.
Top stuff :)
I have refreshed the installer at the top of this thread with:
2.10.0.29
- Removed "Delete all references to [texturemap]" command - since it leaves an image node with no texturemap filename
- Fixed issue where submenu commands (like Import Material) were not working on MacOSX
After installing, can you pls doublecheck the version number at the top of the plugin Setup window to ensure the version number is 2.10.029.
Evolutionary
All working great Paul. Thanks for your efforts.
Hdr studio support and then it's everything the windows boys have :)
Evolutionary
I'd take the [test] off the description, seems very stable now :)
Return to “Poser”
