any docs for network rendering ?
Karba
bcravin wrote:Thank you abstrax,
I have re-installed 2.00 standalone on both workstation and slave. I am running Max plugin version 2.0.7a , I don't have standalone open on either computers. So, now I have my slave showing up in the Max Octane Network Tab, but it is showing up as Invalid Slave. I'm assuming that I'm running the wrong 3ds Max plugin, but I can't seem to find a different version. The link you gave me in the previous post is a large forum so I'm sure If i should be using the version that is in the first post or maybe a later version that was posted...?
Hi
You have to use plugin 2.0a. It is the latest at the moment.
bcravin
Thank you so much! It is working great :)
muski
Does anyone know if there is any performance loss when rendering over the network? Thanks
using octane since the dawn of the dinosaurs :)
coilbook
what means invalid version in network rendering status in 3ds max plugin. seems like it worked yesterday
FooZe
coilbook wrote:what means invalid version in network rendering status in 3ds max plugin. seems like it worked yesterday
Did you update your 3ds max plugin to 2.03? If so you will need to update your slave machine to 2.03 as well.
coilbook
thanks it just came out!
Return to “Autodesk 3Ds Max”
