Hi Luma,luma wrote:I'm experiencing much the same issues. I've placed the GUID=etc in the User Data per the documentation and am using the following link to get at my running instance:
http://aws.otoy.com/?connect=//<instanc ... 1;STATUS=1;
AUTOLOCK=0;WAN=12;GUID=<GUID>
I have yet to be able to successfully attach to the system outside of RDP.
I'm having the same issue also.
Similar to other posts, and to help narrow down the problem for other users, my setup is:
The GUID i set in the userdata instance setup is not the same as i can see when i RDP into the server (think this is the root problem).
Using the URL with either my GUID or the one supplied by the server itself does not connect, i get a timeout error message.
RDP onto the server is fine, and i can see the TCPSVCS.exe service running and the GUID it has created for itself.
I've changed my amazon instance firewall rules (security group) using the defaults supplied by the OTOY image, but to only allow my IP address instead of the world (0.0.0.0/32) supplied as default (this should be incoming traffic only?) -has anyone tested with the normal default security rules?
I'm using the Autodesk OTOY ami.
Tested with my Firefox browser.
Booted the instance once for my testing then shutdown, i've not retested since -but it should work on the first attempt.
Interestingly when i use the URL the page loads as a grey screen with a blue 'i' symbol at the top left of the screen, so i assume that it has started to work, before i then get the timeout message.
