Ok, will check the resolution change issue.benoit_3d wrote:Hello,
Just a general thought about Octane for Softimage. I'm currently using it in a project. It's fast and reliable. I'm just tired to change the resolution each time I have to preview render (it's a well known limitation, I hope you will be able to fix it soon), the second (or even more !) UV support would be also very nice.
Nice work Face !
I use UV´s, but only the first one because Octane can´t use more than one per material.
But i´m working on a plan where you can select the uv you want, per material.
I don´t know how to realize it, but we will see.
When it works, it should be possible to render emPolygonizer/emTopolizer and other self generated uv´s.
face
