Skin shader with SSS
gordonrobb
Looks great most of the time. Has a kind of wax property from some angles. Can you give us some details of the settings?
about the wax effect, probably i have exaggerated a bit with the glossiness :roll:
basically is a specular material with the diffuse texture in transmission, absorbtion and scattering, and the specular map in reflection and roughness with different settings ;)
mib2berlin
Thank you all, I understand the SSS in Octane now much better. :D
Cheers, mib.
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
sigmamoon
bepeg4d wrote:i found the scene in the cinema 4d r14 content browser example scenes, so i decided to give it a try with the integrated plugin for c4d version 0.42. the skin shader is made with a specular material only, no mix material used. 2048 samples in direct light diffuse mode for about 2':40" per frame with 2xgtx590.
Yeah great work
just to tell something, just a little wax effect, but really great final work, i dont know if i could better :)
WebSite compagny
Pixel De Lune
WebSite personnal
SIGMAmoon.com
thanks sigma :)
here is the ocm and ocs without textures and obj (you can find them in the first page), i have slightly reduced the wax effect by increasing the absorbtion power just a little:
specular-skin.ocm.zip
(1.81 KiB) Downloaded 538 times
head_2-bepeg4d.ocs.zip
(8.99 KiB) Downloaded 483 times
gordonrobb
Bum, have loaded it in Standalone, and it works a treat. Have duplicated everything (as close as I can as some of the settings are different) in Lightwave, and it looks nothing like it
i think that you need to adapt the scale value (i had to do the same when i rebuilded the shader from c4d to standalone) if too solid, you need to decrease the scale value, if too trasparent you need to increase it ;)
boeing727223
Looks like my paesano beppe nailed it, now who can duplicate his setup with a DAZ character?
gordonrobb
bepeg4d wrote:i think that you need to adapt the scale value (i had to do the same when i rebuilded the shader from c4d to standalone) if too solid, you need to decrease the scale value, if too trasparent you need to increase it ;)
I can get it to go not too transparent, but its back rather than the colour of the skin image.
gordonrobb wrote:I can get it to go not too transparent, but its back rather than the colour of the skin image.
it's hard to help without an example, could you post a screen capture of the node graph and the result?
Return to “Works In Progress”
