OctaneRender™ for Cinema 4D released
Silverwing wrote:Just got to play around with it a little. Works pretty well.
I noticed that the Materials all have to be in one location otherwise materials will not load sometimes. I guess this has to do with the predefined C4D Texture locations (Preferences, Files, Texturepaths) If you load a texture from any of those defined locations C4D would not show the full path but only the Materials name.
Also spheres are not rendered when "Perfect Sphere" is ticked on. They are rendered in the Preview Window but not in the Render-View. This isn´t that important. Just wanted to mention it!
Just a small question:
Is there a possibility in the plugin to activate camera motion blur?
I want to render animations and the old C4D exporter plugin supported camera motion blur.
Would be great to find a way to make this possible (if it isn´t already)
Raphael
octane need full path, i'm converting paths. It looks project folder, tex folder. I can add texture locations also. But this can cause to waste time little.
sub-frame mblur not yet working, i have working on. I'll check camera blur posibility also
salil raina wrote:aoktar ~ cant get the plugin to activated.. even if the fields are blank it says activated.. and i should restart c4d.. but after restarting c4d .. still not activated.. serial doesnt work! :oops:
awesome release :)
can you check Otoy account page for plugin account status, and numbers?
videoprice
Finally!!! thanks a lot Octane team.
How about shadow catcher?
Richard
salil raina
awesome release :)
checked, and entered in correct fields.. not working..
TonyBoy
I was told earlier that C4D ver 11.5 would be supported, but, "This release requires Cinema 4D 13,14, 32 and 64bit, on Windows XP, Vista, 7 and 8." contradicts that. Can it work with 11.5?
TonyBoy wrote:I was told earlier that C4D ver 11.5 would be supported, but, "This release requires Cinema 4D 13,14, 32 and 64bit, on Windows XP, Vista, 7 and 8." contradicts that. Can it work with 11.5?
sorry but, this is quick launch.
Soon i'll add older versions when is ready. Also mac version soon
@salil raina: can you send me private message to see status. with some sshots of settings window and c4d/c4doctane plugin folder ,
@videoprice:there is a option for that on diffuse materials. Named as matte. also you must check alpha shadow option on render settings
videoprice
ok I get it. Thanks a lot for this plugin
aoktar wrote:@salil raina: can you send me private message to see status. with some sshots of settings window and c4d/c4doctane plugin folder ,
mustardseedsg
So can we also pause and resume renders in C4d now with this integrated renderer, just like the standalone?
Mac OSX 10.12.6 / MBP 15" w Touch Bar, 16GB / Mantiz Venus Thunderbolt 3 enclosure with GX1080 / C4d r19 Octane
badmilk69
For a beta realease, looks and feel pretty final to me, samples scenes are a big plus! just need auto update geometry feature.
i7 2600, 16 GB RAM, 2x Evga 670 SC 4gb, dual boot win7/osxML, 2 SSDs, 3 HDs.
