OctaneRender 3 for Modo [OBSOLETE]
yoshikai
Hi, Paul
I tested substance plugin.
load sbsar is ok. but color image is more darker.(looks like Liner color space)
The substance plugin version is 2.4.0 and octane is 3.6.3.117.901
https://www.dropbox.com/s/588p6whxn0hf6 ... 1.jpg?dl=0
BR
The colorspace issue is fixed in the next OctaneRender for Modo test pre-release (which I will publish in the next 24hrs).
yoshikai
Hi paul.
Thank you. I appreciate it.
I want to using sequence image.
Can I possibly??
The latest version 3.6.3.117.901 didn't works.
anytime crashed when I start rendering button.
sincerely
The recent OCIO support is causing this crash. It will be fixed in the next test pre-release.
Hesekiel2517
Hey there,
I tried texturebaking together with adaptive sampling. When i wanted to view the noisemap i got a bluescreen. I tried that again. This time no bluescreen but a lot of cuda errors. Maybe adaptive sampling isn't supposed to work with AS.
Can you pls try the same thing in Octane Standalone, and if it also gives you the error report the issue in the Octane Standalone 3.06 TEST 4 release thread.
Hesekiel2517
I'm sorry, you are right. Same problem there
Can you post the ORBX file to the Octane Standalone 3.06 TEST 4 thread, where the Otoy devs can take a look. Also post the CUDA errors you are getting.
Hesekiel2517
ok, i did that
MrFurious
Stupid question, is it possible to bake out texture maps without reflections?
Dino Inglese
CG Artist
Melbourne Australia
Octane build 4.04.0.145
Return to “Foundry Modo”
