I really like how you're using RedSpec TGX on all sorts of non - Mil4, Gen, Gen2 - characters.
Really shows the versatility of the product.
Very nice work again!
REDSPEC SSS
- xxdanbrowne
I *need* the DAZ shader!
(weeps uncontrollably)
I understand
It's just that we don't want to rush the product out the door, even if there is huge demand for it.
We want to make sure that everything is running as optimal as possible - just like with the Poser version.
The release is not far away anymore - We'll keep you posted.
Thanks for your patience and your interest in RedSpec, it really means a lot to us
Just to play for time until the upcoming DAZ release
"Sad Girl"
Sad because I can not use the DSON importer for Poser to use Gen/Gen2 (with displacemet / vein morphs 7 boris etc...). There are some trouble with my other scripts (Shaderworks, Netherworks or other).
Poser - Millennium 4 Normal_individual_body_part.poe - Photoshop for better result (shoulder, hair and eyes). Smooth permission was enabled
V4 - DAZ Elite / Aeon Soul - Oy Hair
Rendertime: 20 Min (Quadro 4000) with Path Tracing and Max Depth of 16.
Environment HDR Map: Redspec TGX Official HDR Pack #01 (Map 8)
"Sad Girl"
Hey man,
don't be sad, Boris works just fine with DSON importer.
Extract the files into your standard Poser Runtime folder.
- Start Poser and load up Michael 6 (normal or HD)
- Select Michael 6 and in the Full Body / Actor Morphs set the now prsesent Boris Morphs to 1.0 - do that to the Head as well.
The textures can be loaded regularly and are sitting in the "Materials" tab under DAZ Genesis 2 Male.
Displacement maps are not supported right now - but will be in OctaneRender 2.0
Hoope this helps
CHeers
Hoope this helps
CHeers
two renders just to show TGX in action
RedSpec TGX for Poser / OctaneRender - OUT NOW visit http://redspec-sss.com/
Just a heads-up for all the RedSpec TGX Octane 2.0 users.
TGX is optimized for 2.0 and all Versions you can buy at http://www.redspec-sss.com are compatible to 2.0.
- morphious2013
Once again. That link leads to no options to buy anything.
yes i quick look and it not the most user friendly site, you need big icon saying buy here
W7 64 bit |I7-3970X | GTX 780 X2(6GB) GTX 780TI X2 | 64 GB DDR3 RAM
Real Skin & real hair for Poser / DAZ Studio OctaneRender/iray - coming soon
That derives from the fact that this is our official Homepage and not just a "purchase-hub".
Via a click on the three lines in the upper left corner and another click on "RedSpec Products" in the now opening menu you'll see everything you need to purchase the shaders.
There is a landing page where you can select the software you want to purchase the shaders from (although only Poser versions are being offered right at the moment.)
Once there you'll see the options you have and will find a "Buy Now" link.
However - here is a direct link to our Poser shop page: http://redspec-sss.com/elements.html
Hope this helps
Hope this helps
