OctaneRender 3 for Modo [OBSOLETE]
Round edges are not working in Octane. And this is a big problem! I am rendering CAD files all the day, but it is often not possible to build round edges on object level.
Round edges were significantly improved in Octane 3.05, and Otoy have indicated there are further improvements to be made. If you have specific issues with round edges in 3.05 or later, can you pls post them in the Octane Standalone 3.06 TEST 4 release thread so that Otoy have your bug report on the problem.
yoshikai
Hi, paul
I tested latest version.
IES light support is really helpful for me.
last night, I rendered animation scene.
It failed sunrise animation scene.
please check this parameter.
Directional light phsical sun time animation parameter.(It works only preview window.animation render was not works)
This problem will be fixed in the next release.
Uhlhorn
face_off wrote:Round edges were significantly improved in Octane 3.05, and Otoy have indicated there are further improvements to be made.
Nice to hear! :-) I love Octane more and more!
Uhlhorn
face_off wrote:… and Otoy have indicated there are further improvements to be made.
This is correct. The rounding edges needs a lot more improvement. ;-)
Did you tick Load Cage and Weld Vertices?
Substance Support
You will need the next version of the Substance plugin for Modo for this to work (should be out shortly).
sjogren
face_off wrote:Substance Support
Great news, very excited!
/Niklas
Windows 10 (64-bit) | GeForce GTX 1070 & 970 (416.34) | i7 6850K | 32 GB System Memory
Modo 12.1v2 | Plugin Version: latest beta 4
yoshikai
Hi paul.
I want to using sequence image.
Can I possibly??
The latest version 3.6.3.117.901 didn't works.
anytime crashed when I start rendering button.
sincerely
Uhlhorn
face_off wrote:Did you tick Load Cage and Weld Vertices?
No, I did not. Now it is much better! :-)
But it needs some improvements!
And Otoy should put this information into the documentation. ;-)
Return to “Foundry Modo”
