OctaneRender for Modo 3.03.3 [STABLE]
Thanks Paul!
Win 8.1/64 | Geforce GTX780TI | Core I7 970 | 24GB
I have problems with render region in the new plugin, I cant see the region.
Maybe youre just not seeing the red region border because you arent zoomed at 100%.Tharso wrote:I have problems with render region in the new plugin, I cant see the region.
It looks like the change to using sharp resizing, also changes the visibility of the region border when you arent zoomed to 100%
Thanks funkfunk wrote:Maybe youre just not seeing the red region border because you arent zoomed at 100%.Tharso wrote:I have problems with render region in the new plugin, I cant see the region.
Yes, the change from "sharp" to "smooth" interpolation has broken the render region box. I will fix this in the next release.I have problems with render region in the new plugin, I cant see the region.
Thanks Paulface_off wrote:Yes, the change from "sharp" to "smooth" interpolation has broken the render region box. I will fix this in the next release.I have problems with render region in the new plugin, I cant see the region.
octane plugin is shutting down modo again with renders curves on. Modo SP3 - octane plugin 2.24.2
It is working OK for me. What is the full release number of the Octane plugin that you are using pls?octane plugin is shutting down modo again with renders curves on. Modo SP3 - octane plugin 2.24.2
.87 sry . I will update now and see.
Oh Its ok now ! I work with two computers, Then I tought that was the last version.
