OctaneRender® for Poser (Windows/OSX) 3.03.3 [OBSOLETE]
Whenever I try to "Disconnect" the "Bump" node, I get the following error message:
Fixed in the next release.
Ken1171
I am also getting an error message, but just by moving a prop I've added to the scene. This is version 2.24.0.58. Whenever I translate the prop, the error pops up.
Ken, I cannot reproduce this error. Can you pls try with 2.24.1.60, and if the error persists, send me a scene which produces the exception.
Erick
Thanks for having a look and fixing it :)
I have refreshed the installers at the top of this thread with:
2.24.1.61
- Fixed python exception when disconnecting bump maps
I have refreshed the installer links at the top of this thread with:
2.24.2.61
- Compiled with Octane 2.24.2
- Removed support for the 32 bit version of the plugin
I have refreshed the installer at the top of this thread with:
2.24.2.62
- Added Poser 11 support (see https://docs.otoy.com/Poser/?page_id=423 for details)
- If there is no Infinite light in the scene, and the Daylight environment is being used, and the user does NOT have Expert Mode ticked, a warning is now displayed
- Octane Shadow Visibility is turned OFF by default or the Poser 11 Ground Plane / Dome
panton41
My nVidia driver is crashing on a fairly regular basis with Poser 11 Pro, the latest plugin and standalone Octane Render using RedSpec shaders. I'm using the 358.91 drivers on two GeForce 970 in SLI.
If I had to point fingers, though, I'd be pointing them directly at Smith Micro for releasing an Alpha build as final. Poser 11 Pro is a bad joke they expect you to pay money for. It's less finished and more broken in fundamental ways than the PC release of Batman: Arkham Knight.
Have you tried installing the Octane Standalone installer exe to set your Nvidia time-out settings?
wimvdb
The latest Windows update (1511) seems to have removed the TDRDelay settings in the registry
Installing standalone does restore them again
Configuration: Windows 11 Pro, I9 12900K, 128GB, RTX 3090, P12 b1029
Return to “Poser”
