NEW: Octane X - is finally here! [MEGA FAQ THREAD]
LUKEBB
drunknbass wrote:
aoktar wrote:New c4doctaneX PR4 for Catalina 10.15.7 is available for downloads.
You need to visit your personal Downloads area:
https://render.otoy.com/account/download_archive.php
Honestly hard to make releases for me too! I'll prepare a build for BigSur-PR4 soon, too much branching happened lately
[/quote]
Yes thankyou! And not trying to hurry you along here as I imagine it's pretty complicated. buuuut - do you have an ETA on the Big Sur update? I have a job I have to get out and have already upgraded my OS without checking argh. If not in the next couple of days I'll have to reinstall Catalina. Thanks again.
bengiefons wrote:Hi Just letting you know that I just tested out the Octane X PR4 (Catalina) and I'm having issues with the "Live Viewer Window" most of the time black and if I hit Render I just get a Black screen as well. On PR3 everything is good on those 2 issues.
please, open a scene that is giving you issues with PR4, then go to c4doctane Settings/Other tab, and, at the bottom of the panel, enable all the Log option checkboxes.
Then, load the scene in Live View, then in Picture Viewer, or until crash, then reopen c4d, navigate to c4doctane Settings/Other tab, press the Generate log report button, and share the octanelog_report.zip file, thanks.
ciao Beppe
namshubffm
Just wondering, where is Octane X with Apple Silicon M1 support...
Existing X Versions (incl PR4) all crash during startup
bengiefons
ciao Beppe
Hi there!
Here is the link to the zip file:
https://www.dropbox.com/s/8s87qmz6rv8c4 ... t.zip?dl=0
FYI, I'm using the latest iMac:
iMac (Retina 5K, 27-inch, 2020)
Processor: 3.6 GHz 10-Core Intel Core i9
Memory: 72 GB 2667 MHz DDR4
Graphics: AMD Radeon Pro 5700 XT 16 GB
Ben
Goldorak
PR5 (Big Sur) will add support for M1, and PR6/final Octane X 2020 release will add all plug-ins on Big Sur, add Pime (free tier) and demo versions, and an Octane X standalone app on the app store- we just are doing these last - once we are stable and done with bug fixing - as it takes a lot of time to build these tiers. We want to make sure all known bugs get fixed in studio/enterprise PR5/6 updates on Big Sur before adding prime/demo into the mix.
drunknbass
brunobot
Since I updated from Catalina to to Big Sur, none of the OctanePR are working. I've tried with 2,3, and 4. It literally crashes as soon as a scene is loaded. Is it just me or are you guys also going through this?
delete file:bugreport_20201119_073247.zip
Creating zip file:/Users/animalhouse/Library/Preferences/Maxon/Maxon Cinema 4D R22_F2A48324/_bugreports/octane/bugreport_20201119_073617.zip
Adding file:/Users/animalhouse/Library/Preferences/Maxon/Maxon Cinema 4D R22_F2A48324/c4doctanelog.txt
Loaded Octane DLL:Octane X Enterprise PR4  version:10000200  SDK:PR4
Octane X for Cinema 4D PR4  built for:220   C4D vers:22123
C4D:22123  comp:[Bruno’s MacBook Pro]  OS:[OS X 64 BIT] OS X: Version 10.16 (Build 20B29)  versType:10
CPU:[GenuineIntel, stepping 13, model 14, instruction family 6]  speed:2.4 GHz  numOfCpu:16Ht
Plugins:[houdiniconfig addons advanced render alembic archigrass bitmapfilter bpexchange browser bugslife_client c4d_viewport_render c4doctane-S22 ca ca2 cadexchange clothilde collada14 collada15 colorchoosergui compositing deployment dwg dwgobjects dynamics exchanges expressiontag fbx gltf goz gpurenderer hair i_skp io_obj metrics mkmodeler mocca model mograph motioncam motiontracker nbp newman nodeeditor_material objects onlineupdater projectassetinspector python relaxuv sculpt sculptbrushes shader sketch sky sla spacemouse substance teamrender thinking particles tpoperators uvviewport volumes walkthrough xpressocore xtensions ]
Loaded 90 osl scripts from dir:/Applications/Maxon Cinema 4D R22/plugins/c4doctane/res/osl_scripts
Deleting texCache folder... /Users/animalhouse/Library/OctaneRender/cache/texCache
VRAM used/free/max:0Kb/7.984Gb/7.984Gb  Out-of-core used:0Kb  RAM used:26.887Gb total:32Gb  OpenGL free/total:0/0
>> ProcessUpdate(flags=C cAsyn=0 dDelay=1
FumeFx library initialisation error!
--------------------------- EXPORT LOG ---------------------------
Multi-threaded material conversion, thread count=14
Export materials time= 0.077 ms
Collect objects time= 0.164 ms
Mesh creation time = 29.495 ms.
<<< Render failure detected!!! >>>
Please check render statistics to solve the problem.
 MB:0/0  ST/MOV:0/1  Nodes:12  Tris:156k  DispTris:0  Hairs:0  Meshes:1
 Textures Grey8/16:0/0  Rgb32/64:0/1
OCT:Compute info 2:5106:
OCT:Compute info 2:5106 on device 1:
Total export Time = 639.44 ms
Api update time: 0.199 ms.
>> ProcessUpdate(flags=CMOG cAsyn=1 dDelay=1
>> ProcessUpdate end res:0
Hi brunobot,
there is only Standalone PR4 available for Mac Os 11 Big Sur, at the moment, the plugins are not ready yet:
viewtopic.php?f=33&t=76216
ciao Beppe
Weezer
I’m amazed at some of the comments on here. You upgrade to a brand new OS - and in some cases a brand new hardware architecture - and immediately expect Octane to either just run, or for a compatible update to appear the same day. It’s crazy; updates take time and Octane is immensely complex. Ahmet now has to support multiple versions across several different platforms. I’m as eager as anyone for a plug-in that runs on Big Sur, but let’s give the guy a break and let him do his job. Constantly pressing the button doesn’t make the elevator come any faster.
drunknbass
[size=0].[/size]​​​​​​​​​​​​​​​​​​​​​​​​​​
