OctaneRender® for Poser (Windows/OSX) 3.03.3 [OBSOLETE]
Ken1171
wimvdb wrote:preferredState.pz3 is in c:\users\<yourname>\Appdata\Roaming\Poser Pro\10
Perfect! I know what to do now. Thank you again! ^^
RGUS
Is it just me or is it really difficult to uncheck or check the "LockAspectRatio" check box in the "Render View Settings" window?
A bummer when you want to change the image size.
WEB: http://rgus.deviantart.com/
GPU: NVIDIA GeForce RTX 3090 Ti
RAM: 64GB
CPU: 12th Gen Intel(R) Core(TM) i9-12900K 3.20 GHz
OPERATING SYSTEM: Windows 11 Pro
OCTANE PLUGIN VERSION: 2025.6.0.4.09 Prime BETA
DAZ STUDIO VERSION: 4.24 Pro Edition (64 bit)
Working OK for me. What is your windows font scale set to?
RGUS
10 point... I'll have to set it to something I can't read on my 40" monotor
RAM: 64GB
Mmmm, OK for me at 11 point. Are you using 100% or 125% for the text size?
RGUS
100%
RAM: 64GB
100%
Can you provide a screenshot of the Resolution node edit box pls? And when you say "it really difficult to uncheck or check", what exactly do you mean by that?
RGUS
face_off wrote:
100%
it was all dependent on the font size used for menu etc in the windows interface, I shifted the font down to 9 points and restarted Poser and Octane plugin, problem went away, reset it to 10 points and it was still fine, set it to 12 points and it was difficult to pick the checkbox for 'Lock Aspect Ratio".
Check and uncheck means picking the checkbox for 'Lock Aspect Ratio" from a tick to a no tick, the mouse pointer was not being located over the little square where the tick should appear.
I think the problem has gone away Paul so long as I keep Windows font 10 points or below.
RAM: 64GB
If it is just a font problem, I can spread those 3 aspect ratios out a little - there is plenty of space.
RGUS
Well just in case blind buggers like me need bigger font sizes on bigger monitors... that would be a good idea.
RAM: 64GB
Return to “Poser”
