OctaneRender for Modo 3.03.3 [STABLE]
Is this so then you don't have to re update the materials right? And will this help the transferring materials between scenes?
Usually I just add an octane over ride and change the values in there... Lately I have been just changing the materials and having them convert on the fly from modo so I can transfer materials between scenes easier.
I am sorry, but I am just seeing this as an extra step? Am I missing something? No offense fyi..
Yes - it's an extra step - for those users who want to control a the Modo Material and Octane Override properties from a single slider. In most cases users won't need it - but in some cases it will be very useful.
Dmi3ryd
Can someone help me.
I use 3 cameras in different frames and in preview in all my scene is only one displayed and rendered/
I've cheked render animation right now (( it's not working
Paul please help to fix this
Win 8.1/64 | Geforce GTX780TI | Core I7 970 | 24GB
As per Skype call - untick Load All Frames Into Octane (in case other users have this same question).
Dmi3ryd
Many many thanks!
LFedit
Ahhh gotcha. Yeah was just wondering the advantages and disadvantages for sure.
Great option.
Dmi3ryd
Did some one know Octane plugin support locator animation (and inside animation 2 meshes)? I need manualy refresh every frame to see result :(
Dmi3ryd
when I turn on Load all frames to ctane it works but cameras didnt working :(( I'm very sad
That's right - you need to turn it OFF if you are changing camera's within an animation. https://docs.otoy.com/#42Rendering%20an ... Animations.
Dmi3ryd
Many thanks Paul/ Right now everything is good.
All cameras working correctly and changing properly.
Using Multiple UV Maps
NOTE: You must have Use Render Cache DISABLED in order to render multiple UV maps in Modo901 (hopefully TheFoundry will fix this in a future SP).
Return to “Foundry Modo”
