Which feature do you need the most?
Region Render
139
6%
Network render
85
4%
Render Passes
239
11%
Hair&Fur
287
13%
Particles
229
10%
Multilight
156
7%
Internal Texture Mapping (planar, box, spherical, cylindrical, camera and so on)
88
4%
Undo
104
5%
Volumetric: fire, smoke, clouds
370
16%
Mixing of daylight and HDRI environment
213
9%
Subdivision surfaces (OpenSubDiv)
81
4%
Multi UV channels
129
6%
Rounded edges
131
6%
Total votes: 2251
Oh sorry Roger,
I remembered the discussion but I haven't paid attention to the author :oops:
I can understand your issue... let's see if OpenSL could be useful also in this situation once it will be enabled in v3 :roll:
mbetke
Maybe the list could be cleaned because a lot of stuff has been integrated?
PURE3D Visualisierungen
Goldorak
Agreed. Let's start a new list - after this week's roadmap announcements at GTC and for things that are not covered that we should be considering. That would be the most productive.
Elonius
Hi, I would like a subsurface scattering shader and a metal shader so I can get more control. Thanks.
Hi Elonius,
if you use a medium node in a specular material you can easily obtain any sss effect.
If you look at the Live DB, you should find a good example ;)
About metals, did you know this special metal shader made by roeland?
viewtopic.php?f=73&t=43973
Elonius
Thanks I'll check it out.
Zay
A button to reload only all the newer OBJ/scatter files by comparing the file timestamps.
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 581.57| Modo/Blender/ZBrush/Daz/Poser
leprinoxyz
Udim workflow
longshoes
Live HDR creation in Octane standalone similar to HDR Light Studio
https://www.lightmap.co.uk/hdrlightstudio/whats-new/
aiven
1. Being able to plug a Mix node into Displacement (most important for me, for terrain shaders)
2. More nodes like Multiply (screen, overlay, etc)
aiven.net
5960X | 64GB ddr4 | 1x 1080ti + 2x 980ti
6850k | 64GB ddr4 | 4x 980ti hybrid
6850k | 64GB ddr4 | 4x 1080ti
