Cinema4D 2022.1-[R10] (Previous stable) (26.03.2023)
Xichen Zhao
Hello,
I installed Mac M1 plugin, c4d can't launch, it crashed everytime. How can we fix it?
bugreport_20221126_232102.zip
(960 Bytes) Downloaded 220 times
AaronWestwood
zoppo wrote:
AaronWestwood wrote:Essentially I open ANY project that has a scatter and was made in 2021, click on a scatter, copy, file new project, paste, crash.
Does this also happen when > disable scatter > copy / paste > enable scatter?
Yep, still crashes. Good suggestion though!
Also tried copy/pasting WITH the plane its scattering on so no links break, also crashes.
Again I tested this with about 6 different scatters across 4/5 different projects. Going back to 2021.1.4, works perfectly.
3D Environment Artist
http://www.artstation.com/aaronwestwood
2 x 4090 // 13900KS // 96GB 5600mHz DDR5 // Windows 11
AaronWestwood
aoktar wrote: There can be a bug, that's normal. Also 2022 version is not appeared in one day. You could report it during development period of it. I can't test every scenarios, that's the why we have this period. Production quality is related to contribution of user support.
Oh bugs are totally fine, totally understand :) Im just reporting it now as I didnt have any time to test dev builds and this is the first chance i've gotten to play around.
Send me some example scene(2021) which causes crashes with some video capture and bugreport.zip please.
AaronWestwood
aoktar wrote:Send me some example scene(2021) which causes crashes with some video capture and bugreport.zip please.
As mentioned I cant screencap at the moment, but just triple checked the below project and it happens every time. Just built this in 2021.1.4, swapped over to 2022.1 and it crashes without fail.
Very curious if this happens for you? I'm on S24
SCATTER_2021.zip
(59.5 KiB) Downloaded 245 times
bugreport_20221127_103705.zip
(1.5 KiB) Downloaded 208 times
Xichen Zhao wrote:Hello,
Sorry, c4doctane log is not enough.
Please write to help at otoy dot com asking for Beppe, so I can investigate mor deeply.
ciao,
Beppe
I can copy all and paste to a new scene without any troubles. Even tried in S24, same! Maybe you can try to reset C4D preferences. I can help, not sure! Also bugreport file is not bugreport.zip. It's under _bugreports directory next to prefs directory.
AaronWestwood
Thanks for trying, so so weird! I just reset prefs but same issue (testing with that project I sent), any other ideas?
Sorry I thought I attached that bug report! Was late. Find attached now (is this the right one?)
_BugReport.txt
(348.58 KiB) Downloaded 212 times
AaronWestwood wrote: Thanks for trying, so so weird! I just reset prefs but same issue (testing with that project I sent), any other ideas?
I found that I'm copying all nodes. It's happening when I just copy scatter with child object. Probably missing node and connection to effector slot that's causing a problem. I will check more....
EDIT: It's a weakness in the related function. There is an instant case during copy/paste operation with linked effectors. Somehow it gets the effector link even it's not in scene and crashing. Now fixed by adding some extra controls for avoiding the null case.
twik25
Bug: When using the Standard Surface material - if you have any values or input into the weight of coating layer, unchecking the checkbox for "Coating layer" does not deactivate the coating layer. In fact, I think that is the case for all checkboxes.
C4D 2023
Cinema_4D_EtXJx0SDGD.mp4
(19.8 MiB) Downloaded 2413 times
