OctaneRender® 1.025 beta 2.50 [OBSOLETE]
Jaberwocky
enricocerica wrote:The index slider for specular material is not float anymore, only integer value can be selected.
Edit : Same for filmindex
Yes I thought the same.You beat me to it.
As most I.O.R.'s are between 1 & 2 Link http://en.wikipedia.org/wiki/List_of_refractive_indices
Being able to select only integers for the index would pose a problem.
dkalna
abstrax wrote:
dkalna wrote:hi, first of all, thanks for your continuous effort... now, since 2.50 it's really hard to do anything besides rendering, whole machine is exhausted... am I doing something wrong?
Ok, I've got a few questions for that:
Do you only use the GTX 580 or do you have any other graphics cards?
Which version are you comparing with?
Do you do the comparison using the same scene using the same settings and resolution?
What is the CPU of Octane usage while rendering?
Are only other applications affected that use the graphics card (like Maya) or are there applications like an editor or the web browser that slow down, too?
Marcus
Hi Marcus,
i have find out when it's slowing down, it's when I use pathtracing only, with pmc and direclighting works everything just fine.
Now to your questions:
- I only have one GTX580
- the same problem I have with 2.49b (I have used probably the other settings, pmc)
- I use portal light in my scene (70000 tris)
- CPU is not used at all
- all running appls are affected (fiefox, maya, etc...)
Best regards,
Dalibor
Hardware: Intel® Core i7 920 2.66GHz, 12GB RAM, Gainward NVIDIA GeForce® GTX 580 1536MB GDDR5
Software: Windows® 7 Home Premium 64-bit, Autodesk® Maya® 2012 64-bit, Octane Render™ v1.0 beta 2.52
abstrax
Sorry again for the glitch. It will be fixed on Monday. It's just one line... As a workaround, connect a float2 node to the index pin and choose the IOR in the X value.
Marcus
Jaberwocky
Marcus
Ok Thanks marcus
abstrax
dkalna wrote: Hi Marcus,
Ok, thanks for the info. Could you please test the same scene and resolution in beta 2.46b. I would be surprised, if there is much of a difference, but am curious if for some reason the UI behaves better.
In general, if you render on the same graphics card, that is used for display, the UI feels "sluggish", because during each kernel call, the framebuffer will not be updated. I.e. even though the UI drawing happens, you can't see it. Since beta 2.48b we try now to use smaller work chunks in path tracing and direct lighting, which should improve things a bit, but the general problem is still there and is hard to solve without affecting the performance.
If you really want to work in parallel to rendering, get a cheap display card (any that supports OpenGL 2.1 can be used) and use the GTX headless for Octane rendering only.
Marcus
m.arc.in
Marcus - I have a strange problem with octane 2,50 to.
GTX580, Quadro FX4500, Core I7 920, win7 64.
When I'm openig octane scene for first time everything is ok, but if I try to open other scene after some time everything going crazy. Computer start to works, like Pentium 133, or something like that. CPU load at very low level, everything stoping, hard drives usage is very extreeme.
Same hapens, when I try to exit octane.
Sorry about my english
Regards Marcin
win7 64/core i7 920/32GB RAM/3x GTX 580 3GB 4x GTX 970 4GB/blender 2.79/Rhino 5,0/octane 3
win7 64/core i5-460M/8GB RAM/GTX 460M 1,5GB/blender 2.79/Rhino 5,0/octane 3 (ASUS G73JW)
Elvissuperstar007
m.arc.in wrote:Marcus - I have a strange problem with octane 2,50 to.
Regards Marcin
+1
too .. everything slows down. version 46 b faster
Magog
:o :o :o
Oh my God!
Oh my God!
I was able just now to install the new version of Octane .. and I have found very familiar image on the monitor ..
I did not expect! Thanks guys!!!!!!!!!!!
I'm touched!!
i7 970 3.3 GHz | 12Gb Ram | GTx550Ti for display + Gainward GTX580 1.5 Gb and Zotac 590 3 Gb for Octane | Win7 x64 __ Softimage 2011.5
DayVids
certain hdri's slow my system down to a crawl, .19 Msamples/s. And when I change out the hdri I go back up to normal, (which is between 2.5 and 7.5 Msamples/s).
Also finding that there is some sort of hesitation in the right click menu in the node interface when I mouse over an expandable option. Like its opening and closing so fast that I can't see it several times before I finally expands.
CPU - i7-950 3.06 Ghz, 24GB Ram, Win7 x64, 2 display monitors, GeForce GTX 580 3GB Classified. I'm glad to say I LOVE OCTANE!
vinz
Amazing guys !! thank yu very much for you hard and fast work ! ;)
i7 8700k / 16Gib / GTX980Ti 6GiB / win10x64 1803 / Blender 2.78a / drivers 416.34 + Octane 4.0 Standalone / OctaneBlender
