OctaneRender® 2022.1 XB 0
J.C
promity wrote:The new Photon Tracer turned out to be about twice as slow as the old Path Tracer. I made a simple test scene with small emitter objects in a dark room. And the picture turned out to be absolutely identical, but with a difference of two times in speed. All settings by default (except specific settings Photon tracer).
Have you enabled "Allow caustics" in materials when using Photon Tracer kernel?
System – Windows 11
promity
Yes of course.
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
john_otoy
promity wrote:I made a simple test scene with small emitter objects in a dark room. And the picture turned out to be absolutely identical, but with a difference of two times in speed.
I had a look at your scene and none of the materials have "allow caustics" enabled.
NOTE: you also need to disable "fake shadows" on specular materials.
Here is my Photon Tracing result with those changes (1000 samples or 6m 53s on a 3090)
Here is my Path Tracing result (no fake shadows) rendered for the same amount of time (roughly 3000 samples or 6m 40s)
Here is my Path Tracing result (with fake shadows) rendered for the same amount of time (roughly 2250 samples or 6m 58s)
nuno1980
@any moderator
Please should reply -> viewtopic.php?p=406871#p406871
PT vs PHT kernels - spp nrs
Caustics at PT
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ViewSonic XG2431 24" :D
dynaraton
The new fast caustics is amazing in speed and quality. It is very easy to use. It is a huge addition for us Archviz artists.
Thank you Otoy team!
Asus Prime Deluxe II : Intel i9-10900 X : 128GB G.Skill 3600 MHz DDR4 RAM : (1) Nvidia RTX Pro 4500 Blackwell, (1) Nvidia RTX TITAN: Win11 Pro : Latest Cinema4D
roeland
nuno1980 wrote:@any moderator
The photon tracing is still experimental and we may change some details. We may increase this maximum depth in later 2022.1 builds.
The problem with black areas in complex glass objects is solved by setting a high max depth for the main path tracing rays (specifically the Specular depth). You can still do this with the photon tracing kernel.
A low photon path max depth may cause some very high order caustics to go missing. I expect usually the most visible caustics will have a lower order. Please let us know if you encounter situations where you need higher order caustics.
nuno1980
roeland wrote:The photon tracing is still experimental and we may change some details. We may increase this maximum depth in later 2022.1 builds.
Thank you. :) Does new kernel support Maxwell (eg: GTX 980 Ti)? If you answer "no", I'll buy a new RTX card. But I'm worried for abnormally too high price of videocard. ;)
Caustics at PT
i7-12700KF
32GB DDR4@3600
roeland
The photon tracing kernel is supported on all GPUs that are supported in 2022.1. (this includes the GTX980)
pixym
Hi, Thanks so much to John_Otoy for these tests and remarks on this user scene about Photon tracing.
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - Ram 64GB - RTX4090 + RTX3090 - Win10
Net render : MB Asus Pro WS W790E-SAGE SE - XEON - 128GB - 2 x RTX 3090 - 3 x RTX 2080TI
promity
- aha, that's the main secret! Yes, the render become is much cleaner, but not faster - on the contrary, three minutes longer. Well, let's hope the full version brings us improvements in terms of the GI as well.
Lightwave 3d
