OctaneRender® for 3ds max® v2019.1.5 - 8.17
paride4331
coilbook wrote:Hi Paride,
1. Could you send me a sample scene where you have no difference between old and new volumes? I just want to try on my PC.
In my scene we can clearly see the difference. New volume doesn't scatter well and it is darker. Please try with AO kernel
2. Do you know if phoenix motion blur bug will be fixed soon or it is a long process to fix it?
Thank you
Hi coilbook,
you could try to download my PhoenixFD sample file shared in the forum.
viewforum.php?f=21
Could you describe your issued workflow so that I can do exactly the same to test it?
And could you share a sim file so I will test it using Octane SA from v4 on.
Regards
Paride
coilbook
Thank you
Hi coilbook,
viewforum.php?f=21
Regards
Paride
Hi Paride,
HEre is the scene and the video attached. just turn OLD VOLUME behavior off and on and you will see how white smoke goes to dark grey color. I am surprised it works for you. Thanks
vol bug.mov
(2.69 MiB) Downloaded 3093 times
new vol bug.zip
(6.88 MiB) Downloaded 235 times
mbetke
I have question about Hair & Fur support.
One scene instant crashed 3ds max when I just click render. It's only simple model of a cat with H&F world modifier.
Is H&F supported or not? Maybe I have to do something special?
PURE3D Visualisierungen
paride4331
Thank you
Hi coilbook,
viewforum.php?f=21
Regards
Paride
Hi Paride,
Hi coilbook,
thanks, actually it seems that something is wrong.
I'm going to understand what is happening.
I will let you know asap.
Regards
Paride
mbetke
Shadowcatcher is still messed up in this relase.
See this report of mine:
viewtopic.php?f=80&t=73563&start=30#p376163
paride4331
mbetke wrote:Shadowcatcher is still messed up in this relase.
Hi mbetke,
it depends on v2019 SDK; it seems that enabling shadow catcher, it turns to shadows catcher material.
Regards
Paride
neonZorglub
mbetke wrote:I have question about Hair & Fur support.
Hi mbetke,
Hair and fur is supported, but we can only get it as a single big mesh, not directly using Octane's hair..
One possible reason for a crash can be memory usage if too many hair are created..
Also, with Hair and fur, there can be cases where the geometry normals are not created properly : you could try to add a 'normal' modifier to your geometry..
Here is a small Hair and Fur sample, to check that this works for you.
hairAndFur_SamplePotato3.zip
(1.61 MiB) Downloaded 244 times
mbetke
Hi mbetke,
Regards
Paride
It turns to shadow catcher material feature of course. But in recent versions I was able to adjust the transparency of the shadow and match the scene. Now it is pitch black and material controls in material editor don't work any more as soon as I click the shadow catcher checkbox. This needs to be fixed because at the moment shadow catcher is nearly unusable.
mbetke
Hi mbetke,
The scene seems to be 3dsmax 2020. I only installed version 2019. :(
neonZorglub
mbetke wrote:
Hi mbetke,
The attachment hairAndFur_SamplePotato3.zip is no longer available
Ooppss, sorry, here is a max2017 version:
hairAndFur_SamplePotato4.zip
(1.6 MiB) Downloaded 230 times
