OctaneRender 4.05 for LightWave Production build 4.05.0.0
juanjgon
BorderLine wrote:Hi JuanJo,
IS it Ok for LW 2020 ?
Nope, sorry. I'm afraid that there is not going to be an Octane 4.05 plugin for LW2020, although you can try to use the LW2019 plugin to check how it works.
Only Octane 2019.1 and 2020.1 are updated currently including plugins for new LightWave versions.
BorderLine
Working with LW2020 ! Cool !
KVNOODLES
Nope 4.05 doesn't work properly in lw2020, the octane render target menu doesn't appear in the Open Editor.
I've tried 2018 and 2019 version of the plugin (4.05...)
Sad because it seems that the only thing is broken is the access to the render target menu...
BorderLine
Working good here !
KVNOODLES
Can you access to the Octane RenderTarget options in the nodal ? It seems to be broken, I've tried on 2 differents workstations and I got the same issue with the Nodal Options that's not popping at all in the right menu.
Octane Lights seems to be invisible in opengl view too.
I'm using octane 4.05 for lw2019 on LW2020.02
SpawnSP
KVNOODLES wrote:Hi,
I'm also having this problem. Render target node is missing on 4.05 and LW2020.
BorderLine
No problem here with render target node ! It's OK with 2019 and 2020 !
KVNOODLES
Ok but it doesn't help us with lw2020 and Octane 4.05 issues, for the lights and the opengl problem, I can do a functional workaround...
But for the missing rentertarget node, I don't get it...
Any tricks or advices perhaps ?
ranlod
RenderTarget-Node without Options.. in LW2020.0.2 What can i do?
juanjgon
Sorry, Octane 4.05 doesn't officially support LW2020. This LW version was not available at that time. In any case, I've seen other users working with it, so perhaps there are workarounds to resolve these issues.
