OctaneRender® for 3ds max® v4.05 - 6.21
paride4331
Buraq wrote:
zerozerozero wrote:paride4331, hi look please! When you add an image, the program crashes. This is in an empty scene.
I already reporded weeks ago. They are ignoring all problem V4 for now!
Hi Buraq,
I asked you twice to share in pm your issued scene to test them and make a report to developers, you did never answered me.
Regards
Paride
paride4331
thekwen wrote:Epilogue:
Reopening the same files that was working yesterday, 3dsmax crash ...
Testing ... testing ... to see that when i install 6.20 or 6.21 the hair and fur file works once and once only, after that it crashs ...
Downgrade to 6.14, everything seems to work more than once ...
Octane nightmare ...
Hello thekwen,
I sent this issue to developers, meanwhile you can try to set
Global preferences > Trouble shooting:
Enable Broadcast PRE EVAL notifications: NEVER
Enable Broadcast notifications on frame change : NEVER or 'Same as Kernel "broadcast render" with hair and fur animation.
Regards
Paride
paride4331
The attachment crash.JPG is no longer available
Hi zerozero
I can't reproduce your issue.
Said that would be better to use Octane RGB image texture node as in my screenshot.
Regards
Paride
Buraq
Hi Buraq,
Regards
Paride
You asked right but I gave up. This bitmap case totaly difrent. Even empty scene, it is crahing. I am using 4.04_-_6.17 it is working.
paride4331
Hi Buraq,
this is the right Octane RGB image texture node workflow, it doesn't make much sense using 3dsMax bmp node.
I can't replicate your crash, if you can share an issued crash file, I will try to figure out and report to developers.
Regards
Paride
zerozerozero
Thank you Buraq, otherwise I’ll upload every image, I’ll just go crazy. Have to roll back to this version 4.04_-_6.17.
