OctaneRender® for 3ds max® v4.00-RC7 - 6.09 [OBSOLETE]
Done in PM
Get this error while just changing a material I use for months across my scenes. Have to restart 3ds max to make Octane work again. The material is just a common glossy material. Nothing special nor a big scene.
CUDA error 201 on device 3: invalid device context
-> failed to create link
device 3: failed to create OSL compile context:
device 3: failed to compile module 0
CUDA error 201 on device 0: invalid device context
device 0: failed to create OSL compile context:
device 0: failed to compile module 0
CUDA error 201 on device 1: invalid device context
device 1: failed to create OSL compile context:
device 1: failed to compile module 0
CUDA error 201 on device 2: invalid device context
device 2: failed to create OSL compile context:
device 2: failed to compile module 0
PURE3D Visualisierungen
- paride4331
mbetke wrote:Get this error while just changing a material I use for months across my scenes. Have to restart 3ds max to make Octane work again. The material is just a common glossy material. Nothing special nor a big scene.
Hi mbetke,
thanks
Regards
Paride
- paride4331
Hi HHbomb,HHbomb wrote:Done in PM
thanks,
I'm investigating, it's strange, your issue changes changing blackbody power.
I will let you know.
Regards
Paride
Thanks, it look like alpha don't take in account the opacity texture and treat all the surface as a full emitter....
I get a lot of crashes of max when opening "environnement and effects" ( 8 ) in 6.09 and 6.08 especially when having a hdr map in environnement texture.
- SergKlyosov
Hi Paride,
Can we somehow save compressed textures to a disk? Texture compression of large textures is pretty slow and it would be more convenient to compress them ones and then reuse that compressed file and don't wait 15 min for compression each time 3Ds Max is restarted
Cheers
Cheers
Win 10 64 | RTX 3090 | i9 9980XE | 64GB RAM
- paride4331
Hi SergKlyosov,
compression is on the fly, I recommend saving textures to DDS textures files.
Regards
Paride
Regards
Paride
- SergKlyosov
Hi Paride,paride4331 wrote:Hi SergKlyosov,
Regards
Paride
Thank you for the reply, but didn't quite understand your answer
What is DDS files? Do I need to save textures in that format from another application like Photoshop or MARI?
- paride4331
paride4331 wrote:HI HHbomb,HHbomb wrote:Hi, Paride, but I have "visible on specular unchecked" in black body...
Here is the same render with a diffuse material applied to all objects.
sorry, I'm probably doing something wrong, caould share your scene (in pm if you want) please?
Regards
Paride
Hi HHbomb,
I think you should use black-white images in opacity slot, if you want to mask that's the way.
if instead you want to have variable emission, use the texture in texture emitter.
Regards
