OctaneRender™ 4 RC 6
calus
wallace wrote: OK, I think you have a point in masking. How about this?
Basically I can extend the universal material later by adding a "Transmissiveness" / "Transmission Map" (or some other name) to it after stable, if it is specified, then it would use the mask value to determine the degree of transmission (the disney way), if not then it would use the current way (the transmitted energy is those that is not reflected off in upper layers).
Aff, so this is already too late to change the default implementation ?
obviously extending the implementation later with another option is ok, but this will make the material more complicated/confusing and this is what I wanted to avoid, also is there any benefit of the current implementation compared to have only the disney way ?
Pascal ANDRE
wallace
calus wrote: Aff, so this is already too late to change the default implementation ?
Like I have mentioned before, it works the same way as diffuse reflection / diffuse transmission in diffuse material, so apart from it making more sense physically, it also allows me to fit diffuse bsdf in there.
It's not possible to replicate the diffuse bsdf in Octane with a simple transmission mask, so it would be best to leave the default behavior as is while I add a lambertian option to the BRDF option.
It's not going to be much more complicated because at the end of the day we'll still be adding one pin either way, it's just that the default behavior is different when no node is connected to the pin.
calus
wallace wrote: Like I have mentioned before, it works the same way as diffuse reflection / diffuse transmission in diffuse material, so apart from it making more sense physically, it also allows me to fit diffuse bsdf in there.
Not sure to well understand everything you say here :oops:,
I guess I have to see the modifications implemented to fully understand, so let's wait and see :)
Pascal ANDRE
FrankPooleFloating
:? Is Diffuse/Matte (Shadow Catcher) gaining energy in 4 RC 6, or just completely broken?!!... I just went to render a client's updated product in a scene that was originally done in v3.x in Lightwave -- which now has 4 RC 6 plug -- and I am having a hell of a time trying to get my shadow catchers (in multiple scenes) to even remotely act like they did before... Shadow catchers start super grainy, then are blowing out big-time real quick and millions of dang fireflies are everywhere!...
Edit: Had to switch to glossy white floor and just do separate product and shadow renders -- for tonight, to get this gig out the door -- but I'd still love to know if there is something wrong with diffuse/matte...
abstrax
FrankPooleFloating wrote::? Is Diffuse/Matte (Shadow Catcher) gaining energy in 4 RC 6, or just completely broken?!!... I just went to render a client's updated product in a scene that was originally done in v3.x in Lightwave -- which now has 4 RC 6 plug -- and I am having a hell of a time trying to get my shadow catchers (in multiple scenes) to even remotely act like they did before... Shadow catchers start super grainy, then are blowing out big-time real quick and millions of dang fireflies are everywhere!...
Not that I know of. Maybe send me the scene so I can check. Thanks.
osiosiosi
abstrax wrote:
osiosiosi wrote:Still...
00:55:34.273: +++++ Plugin running.
03:35:03.922: CUDA error 2 on device 0: out of memory
03:35:03.923: -> failed to allocate device memory
03:35:03.925: device 0: failed to upload data texture 4 of context 0
03:35:03.927: Render engine failure occured! (WARNING)
Thanks for the report. Is it possible that you actually run out of memory? Data texture 4 is used for geometry data.
What is your current system configuration you are using (OS, CPU, RAM, graphics cards, VRAM, graphics driver version)? Do you have out-of-core enabled? Does it render in older version?
Thank you for your help.
I am so sorry... it was my fault.
Happy to say OOR works for me now in Standalone and DAZ plugin! I cant thank you enough for making this work :-D
haze
Can you tell us what you did to fix it? Any kind of info about this problem is very welcome
