Version 4.0-RC5 (Obsolete release candidate)
divasoft
Weirdpictures wrote:Hi Ahmet,
we did some test renders with the new build today and noticed that our renders always stopped after 40 - 70 frames, when we had a denoiser pass activated. If we turn off the denoiser pass everything rendered fine, no problem. The log showed the denoiser cuda error. Are we missing something? Do we need a new cuda version?
Otherwise the build is pretty amazing and works great for us.
Thanks for the hard work,
Martin
Yes, i confirm this problem.
abstrax
Martin
That's a bug in Octane and will be fixed in the next release. The underlying problem was that some resources didn't get released when a device gets disabled and then enabled again for denoising, which happens in some plugins after every frame. We are trying to release a new bug-fix version as soon as possible.
Weirdpictures
Martin
Ah ok, good to know. We are about to instal different cuda and graphics drivers in order to troubleshoot and see if that would help, but maybe we rather stay with the system that is going now, since it is quite stable besides the denoiser render bug.
Thanks for letting us know.
Best,
Martin
Kalua
y81r wrote:in LV, when Look resolution is active, compare A/B slider not move.
c4d r19.068
Same here. Also: sometimes the transmission pass wont show the right transmition color while the beauty pass shows correctly.
Mostly the plugins looks amazing!
C4D 2025.3.3 Octane v1.9.4 // Octane SA 2026.4, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
frankmci
I understand from the release notes that the Default Environment Color has been moved from the general preferences settings to a scene specific preferences setting. It seems that TeamRender Clients are not picking this info from the scene, and defaulting to full white. We tend to use full black as our default, so this can cause some significant issues.
A workaround is to add a black RGBSpectrum OctaneSky to every scene, first, but that really shouldn't be necessary.
Is anyone else seeing this behavior?
Additionally, the TeamRender Clients seem to be having difficulty letting go of their Octane licenses, often causing a hang which requires a forced quit or sometimes an Unexpected Quit. Subsequently, the only way to release the license is to launch the full C4D app on the machine in question and then quit, or manually sign out of Octane. Launching and quitting TeamRender Client, even without any crash, does not release the license.
My testing machines, both the master and the RenderClient are C4D R19.068, OctaneRender 4 RC 5, C4D plugin RC5. Mac OS 10.12.6.
Thanks for any insight.
(edit) and I just had a couple of those TR Client Octane crashes. One took down the whole TR Client app, the other was on re-launching the app after the first crash and is explicitly a plugin crash. "The plugin c4dOctane_R19.dylib has crashed. More information can be found in..."
(edit Part Deux) ...and it looks like it's our old friend the Denoiser causing the crashing problem, specifically, Denoiser + TeamRender. An example scene will render fine without denoising in both full C4D and TeamRender. The same scene will render fine with denoising on, if rendered with the full C4D app. The same scene will crash with denoising on, if rendered with the TeamRender on the same machine that renders the other two, all other settings identical.
plugin_BugReport.txt
Plus a more specific plugin crash report
(332.65 KiB) Downloaded 362 times
TRCleint.crash.txt
TeamRender Octane crash report
(323.95 KiB) Downloaded 349 times
jelly
Hello,
running c4d R20 + octane render 4 RC5, can not get the metal material to work, it remains white. I have tried all the BRDF modes with no difference. Moving the IOR slides has no effect (Artistic, IOR+color, rgb IOR)
Works fine on c4d R19 with 3.0.8.
Am I the only one with this issue? Is it a known bug?
Windows 10: Cinema 4D R19 + Octane 3 plugin
http://www.renderingart.it
Studio21
@JELLY
works fine here. did u increase the specular map value?
Best,
G
jelly wrote:Hello,
You should give a value to specular map.
Studio21
aoktar wrote:
jelly wrote:Hello,
Ahmet perhaps its a good idea to have the specular map at 1 as default?
Btw, really having a good experience so far with this version. well done! :)
Best,
G
Studio21 wrote: Ahmet perhaps its a good idea to have the specular map at 1 as default?
Not because it's not a metallic material by default. Specular_map will be 1.0 if you create by "create metallic material" command.
