OctaneRender™ Standalone 3.08.1
fabian19
Hi Fabian,
Yes there is a way to enable logging into a file for the net render slave and daemon. For that you would need a text file for each of these that define a bunch of log flags which will hopefully shed some light onto the issue:
- Please open the OctaneRender Daemon 3.08.1 bundle and then copy the content of the attached ZIP file into the sub-folder Contents/MacOS. It's basically two text files defining the log flags for the daemon and the slave.
- If the daemon is still running, change into its terminal and press CTRL-C to stop it.
- Then restart the net render daemon.
- Both the net render daemon and slave will start logging into the files octane_daemon_log.txt and octane_log.txt. You might find those files either in the application folder (if you've got write permissions to it) or under your user folder in ~/Library/Caches/octane_slave_daemon and ~/Library/Caches/octane_slave.
The try to reproduce your problem and when it happens, please send me the log files so I can investigate what's going on.
Marcus
Hi Marcus,
here is my output, is always good to be able to activate the debugging .. :-)
Last login: Mon Jun 11 07:59:22 on ttys007
12Core:~ fabian$ "/Applications/OctaneRender Daemon 3.08.1.app/Contents/MacOS/octane_slave_daemon" --slave "/Applications/OctaneRender Daemon 3.08.1.app/Contents/MacOS/octane_slave" --alias "12Core" --port 48000; exit
[06:06:50.139]             Started logging on 11.06.18 08:06:50
[06:06:50.139]
[06:06:50.139]             Flag                      Type    Value      Prefix       Description
[06:06:50.139]             ------------------------- ------- ---------- ------------ --------------------------------------------------------------------------------
[06:06:50.139]             daemon                    release 1          "daemon"     Enables general logging of the slave daemon.
[06:06:50.139]             daemonDetail              release 1          "daemon"     Enables detailed logging of the slave daemon.
[06:06:50.139]             logAppendToFile           release 1          ""           If enabled, logging will be to the already existing log file appended
[06:06:50.139]             logFlags                  release 1          ""           If enabled, all log flags will be dumped during startup
[06:06:50.139]             logFlushTime              release 100        ""           The time (ms) after which the log is flushed. If set to 0, the timer based flush will be disabled.
[06:06:50.139]             logForceFlush             release 0          ""           If enabled, every logged line will be flushed
[06:06:50.139]             logJuce                   release 0          "JUCE"       If enabled, JUCE logging will go through the logging framework of Octane
[06:06:50.139]             logPrefix                 release 1          ""           If enabled, each log line will have a prefix
[06:06:50.139]             logTime                   release 1          ""           If enabled, each log line will have a timestamp
[06:06:50.139]             logToDebugConsole         release 0          ""           If enabled, logging will go to the debug console (Windows only)
[06:06:50.139]             logToFile                 release 1          ""           If enabled, logging will go to a log file
[06:06:50.139]             logToStdout               release 1          ""           If enabled, logging will go to standard out (when set to 1) or standard error (when set to 2)
[06:06:50.139]
[06:06:50.139] daemon    : Command line:
[06:06:50.139] daemon    : --slave "/Applications/OctaneRender Daemon 3.08.1.app/Contents/MacOS/octane_slave" --alias 12Core --port 48000
[06:06:50.140]             Launching slave to gather information:
[06:06:50.140]
[06:06:50.140] daemon    : using free port 48001 to communicate with slave
[06:06:50.387]             Started logging on 11.06.18 08:06:50
[06:06:50.387]
[06:06:50.387]             Flag                      Type    Value      Prefix       Description
[06:06:50.387]             ------------------------- ------- ---------- ------------ --------------------------------------------------------------------------------
[06:06:50.387]             activation                release 0          "activation" Release log for the activation manager
[06:06:50.387]             apiChangeMgr              release 0          "apiChngMgr" Logs ApiChangeManager::update().
[06:06:50.387]             apiForceConnectChecks     release 0          "apiChecks"  Enforces validation of node-pin connections.
[06:06:50.387]             apiNodeSystem             release 0          "apiNodeSys" Logs all write operations in the API node system.
[06:06:50.387]             apiProject                release 0          "apiProject" Logs all important calls into ApiProjectManager.
[06:06:50.387]             apiRender                 release 0          "apiRender"  Logs all important calls into ApiRenderEngine.
[06:06:50.387]             appShutdown               release 0          "appShutdow" Dumps information about application shutdown
[06:06:50.387]             cacheLoad                 release 0          "cacheLoad"  Dumps information about the data cache load
[06:06:50.387]             cudaAlwaysSync            release 0          "cuda"       Enables synchronization after each kernel call
[06:06:50.387]             cudaProf                  release 0          "cudaProf"   Enables general logging of CUDA profiling.
[06:06:50.387]             cudaProfDetail            release 0          "cudaProf"   Enables logging of single CUDA activity records.
[06:06:50.387]             daemon                    release 1          "network"    Not used.
[06:06:50.387]             dumpAlembicObjects        release 0          "AlembicObj" Dump data about exported Alembic objects
[06:06:50.387]             heartbeat                 release 0          "network"    Enables logging of the network rendering heartbeat.
[06:06:50.387]             imageSaving               release 0          "imageSavin" Logs saving of render images.
[06:06:50.387]             licenseUsage              release 0          "licUsage"   Release logging flag for inter-process license usage
[06:06:50.387]             logAppendToFile           release 1          ""           If enabled, logging will be to the already existing log file appended
[06:06:50.387]             logFlags                  release 1          ""           If enabled, all log flags will be dumped during startup
[06:06:50.387]             logFlushTime              release 100        ""           The time (ms) after which the log is flushed. If set to 0, the timer based flush will be disabled.
[06:06:50.387]             logForceFlush             release 0          ""           If enabled, every logged line will be flushed
[06:06:50.387]             logJuce                   release 0          "JUCE"       If enabled, JUCE logging will go through the logging framework of Octane
[06:06:50.387]             logPrefix                 release 1          ""           If enabled, each log line will have a prefix
[06:06:50.387]             logTime                   release 1          ""           If enabled, each log line will have a timestamp
[06:06:50.387]             logToDebugConsole         release 0          ""           If enabled, logging will go to the debug console (Windows only)
[06:06:50.387]             logToFile                 release 1          ""           If enabled, logging will go to a log file
[06:06:50.387]             logToStdout               release 1          ""           If enabled, logging will go to standard out (when set to 1) or standard error (when set to 2)
[06:06:50.387]             makeAllInspectable        release 0          "geometryAr" If enabled, all geometry archives become inspectable. Should only be used if you know what you are doing.
[06:06:50.387]             meshValidation            release 0          "validation" Logs errors of the mesh data validation
[06:06:50.387]             moduleData                release 0          "moduleData" Logging for the loading/storage of module data
[06:06:50.387]             moduleLoader              release 0          "loader"     Logging for module loading and unloading.
[06:06:50.387]             netRender                 release 1          "netRender"  General logging of network rendering
[06:06:50.387]             rdStart                   release 0          "cuda"       Logs information about the creation and start up of render devices and threads.
[06:06:50.387]             subdivider                release 0          "subdivider" logs info about the subdivision process
[06:06:50.387]
[06:06:50.387]             OctaneRender 3.08.1 (3080100)
[06:06:50.387]
[06:06:50.505] daemon    : slave connection created
[06:06:50.505] daemon    : slave connection established
[06:06:50.505] daemon    : started to monitor slave
[06:06:50.521] daemon    : received heartbeat message 'AUTHENTICATING' from slave
[06:06:56.394]             Launching net render slave (3080100) with master 0.0.0.0:0
[06:06:56.394] netRender : starting net render slave
[06:06:56.395] netRender : stopping net render slave ...
[06:06:56.395] daemon    : received heartbeat message 'SLAVE_INFO' from slave
[06:06:56.395] daemon    : slave has version 3080100 and provides 2 GPU(s)
[06:06:56.404] daemon    : slave connection closed
[06:06:56.404] daemon    : stopped monitoring slave
[06:07:00.428]             detected that slave is hanging after initialization -> stopping slave
[06:07:00.428] ERROR     : failed to send stop message to slave
[06:07:10.962]
[06:07:10.962]             Stopped logging on 11.06.18 08:07:10
[06:07:10.962]
[06:07:11.448]
[06:07:11.448]             Stopped logging on 11.06.18 08:07:11
[06:07:11.448]
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
i rechecked the driver infos:
i have installed:
macOS 10.12.6 (16G1408)
NVIDIA 378.05.05.25f09
CUDA 387.178
Hope that helps,
Fabian
zoppo
No answer regarding the Offline Mode??
zoppo wrote:Is the Offline Mode back again? I can't use 3.08 w/o my render clients.
Mon Apr 23, 2018 9:53 pm:
Goldorak wrote:Sorry for the inconvenience - while this is otherwise a feature complete release, we should have also noted that the offline system for 3.08+ is still at least a week or more out as we compete testing on a new backend for this. If anyone requires offline mode sooner, I’m recommending staying on 3.07 for just a little longer. Please contact help desk if there is a hard and immediate requirement for offline mode with 3.08.
C4D 2025 | Win10
abstrax
fabian19 wrote:
Hi Fabian,
Marcus
Hi Marcus,
[06:06:50.139]
[06:06:50.139]
[06:06:50.140]
[06:06:50.387]
[06:06:50.387]
[06:06:50.387]
[06:07:10.962]
[06:07:10.962]
[06:07:11.448]
[06:07:11.448]
logout
Saving session...
...completed.
i have installed:
CUDA 387.178
Hope that helps,
Fabian
Hi Fabian,
Thanks for testing. For some reason, the slave immediately shuts down after startup. Are you using C4D or the Standalone? If you are using C4D as net render master, could you try to get network rendering working on the Standalone and let me know if that works?
Thank you,
Marcus
manalokos
Dear all.
I have mentioned that there is a bug in the UNDO on this latest standalone version, but nobody seems to care...
I have many coleagues complaining that the UNDO sometimes reverts the scene some 20 or more UNDO levels back, so hours of work are being lost.
It is not a trivial bug, please reply.
abstrax
manalokos wrote:Dear all.
Sorry, I missed your report. How can we reproduce the issue? The undo system is quite complicated and without a more detailed description of when that happens or a way to reproduce the issue there isn't much we can do about it.
zoppo
_____________________________________________________________________________________________________________________________
HELLO? ANYONE?
Are you just going to ignore questions regarding the Offline Mode?
I have not been able to use the current so called "stable version" for two months now because of this.
zoppo wrote:No answer regarding the Offline Mode??
C4D 2025 | Win10
PolderAnimation
Hi, maybe this is a know issue but motion blur on a displacement mesh does not work is that something that will be resolved?
Win 11 | Dual RTX 5090 | AMD Ryzen 9 9950X| 192GB
manalokos
Hello Abstrax,
Thanks! I've gotten reports that the UNDO jump an undetermined ammount of steps back, it doesn't happen all the time
se we don't know in what circunstances this happens, a coleague of mine says it happened while making a group and re-compiling.
It happened to me 2 or 3 times, but the bad thing is not to loose 15 minute of work, but having work undone without knowing about it.
That is why I was asking if someone else had this kind of problem?
Kind regards
Filipe
cfrank78
Hello Marcus, hello Otoy Team!
I installed the last 3.08 version with the latest 398.11 drivers. Still the old error NO CUDA DEVICES FOUND when using my gtx 780 ti cards.
Guys this problem is now for MONTHS. I phoned with nvidiy, they say its a otoy problem. I talk to you and you say its a nvidia problem.
In win 7 it works in 8 and 8.1 it doesnt and win 10 i dont have. 387 drivers still work. Guys this is a no go. Since MONTHS. I have to update very soon to new drivers and if it will not work soon (VERY SOON) this will be a reason to me to leave you guys and i really dont want that. But thats really a no go problem!
Please answer and tell me what you guys are doing about this problem.
Thank you and have a nice day - Chris!
Hi Chris,
if you are having the NO CUDA DEVICES FOUND error, the issue is in the Nvidia drivers version installed, and any kind of CUDA application that runs on your system, not only OctaneRender.
Have you contacted the support of your harware reseller?
Have you tried to use DDU to completely remove all previous drivers installed?
http://www.guru3d.com/files-details/dis ... nload.html
and performed a clean installation of 387.92 drivers?
A lot of users are working with 388.13, or 391.35 drivers, without stability issues, but it depends from motherboard model, Win version, and Nvidia drivers installed, not from OctaneRender itself.
You don’t need the latest Nvidia drivers, unless you have a Titan V.
ciao Beppe
