Version 3.08-RC4
Aleksei
rayrayato wrote:I am also getting a random switch from pathtracing to infochannel kernel. Not sure what key i'm pressing but it's happening a lot on this project. Is there a keyboards shortcut table posted anywhere I can look at?
The same for me. Had a lot of rendering work recently and noticed the same multiple times. Not sure that is about shortcuts. Looks more like bug.
RTX 4090 | Ryzen 9 7950X3D | 64GB | Win 11 23H2
philcoffman
Any update on when the C4D plug-in will support the Titan V? I keep hearing that it's coming. Did I miss anything?
Pls you should provide some good information about this! What's the exact steps to reproduce it again?
Iceman9
Regarding Octane switching to info-channels. I see now that I'm not the only one w/this bug. 3 other users have reported.
The only pattern I could see is it often happens after changing attributes with the material node system.
Iceman9 wrote: Regarding Octane switching to info-channels. I see now that I'm not the only one w/this bug. 3 other users have reported.
I'm aware of it's a problem which has been reported by a few users. Problem is that to don't know what causes it and why it happens sometimes.
Changing from node editor? Node editor or settings window is open while doing it?
Iceman9
I was trying to discern the trigger point. I'm not sure. Perhaps the act of closing the node editor window. It wouldn't always happen. Maybe it's the presence of certain nodes? Or the selection/state of certain nodes within that window.
Iceman9 wrote: I was trying to discern the trigger point. I'm not sure. Perhaps the act of closing the node editor window. It wouldn't always happen. Maybe it's the presence of certain nodes? Or the selection/state of certain nodes within that window.
My only suspect is about newly added solo mode. It may be due functions which handle that.
Iceman9
If that is newer code...that might make sense. This bug never happened to me until the final release of 3.08. (Maybe it existed before then but I never saw it.)
I haven't used the solo mode yet but maybe something there.
niestudio
Hi Ahmet,
I think you might be onto something suspecting the solo node as the culprit.
I have seen this once while working, and it happened on launch.
I haven't been able to trick it into info channels, but I can consistently get it stuck in solo node mode.
Here is a screen recording of it happening.
Hope this helps.
info_channel_test1.mp4
(18.13 MiB) Downloaded 4217 times
OSX 10.12.4 | Intel 12 core @ 3.33 ghz | 128 gb ram | NVIDIA GeForce GTX 1080TI | Ubuntu Linux slave with 3x 1080ti
niestudio wrote:Hi Ahmet,
Hope this helps.
Is it what you said before?
