IPR renders fine. F9, F10 crash. Scene with heavy instances.
asher
Thank you Juango!
I will download and give it a try.
Gracias!
Asher
GTX TITAN, TITAN Black, 780Ti
WIN 7/64
I7
Asrock Extreme 3 motherboard
asher
Hola Juanjo!
Yes, by disabling the preview window the cash issue is not there anymore. I am supriced you could not reproduce the carash on your side, but what you have done under IPR options does solve the problem.
In any even, it is a feature that should have been there anyway as my guess it would make renders a bit quicker anyway.... and save memory.
Thank you for your always superb service and diligence! :D
WIN 7/64
I7
johnkarner
juanjgon wrote:What happens if you set only 2 or 3 steps in the motion blur (change this parameter in the LW instance generators and in the Octane render options)?
I've seen also problems like this if you have 0 scale instances in one or more frames. Is it possible that any instance could have a 0 scale?
This information saved my sanity. Thanks for the info. Was scaling the instances parent to 0 to hide the instances in certain times during my shot. (.01 and they don't crash anymore.) Odd that it only occurred on my 12th version of render the same scene setup, with LESS instances than before.
Return to “Lightwave 3D”
