Version 3.06-TEST4.1 (WORK IN PROGRESS BUILDS)
Studio21 wrote:i noticed that too
It's here. Maybe issue with resources?
Do you see mixMat-icon.png file under "c4doctane/res"?
Yambo
Restarted c4d and now i can see the MIX icon. weird.
Another issue that came back a while ago (don't think it's related to this version only, This issue you already fixed before and it's back sometime before)
When loading a material into the live db with same transform node connected to the few image textures, Then when loading it back from the livedb the transform node duplicates. and it's super annoying on complex materials.
Would very appreciate you solving it again.
Y
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0 :)
https://yambo.me
dh921911
Not sure if related to what a previous poster mentioned, but im getting a lot of crashes when working with the Node Editor. Usually associated with moving, copying, or deleting groups of nodes.
dh921911 wrote:Not sure if related to what a previous poster mentioned, but im getting a lot of crashes when working with the Node Editor. Usually associated with moving, copying, or deleting groups of nodes.
There is no chance there for test builds. What was the your previous stable? Make sure "auto load materials" enabled and LV is active.
rodross
Thanks Ahmet for the hard work. Here's an example of the fruits of your labor.
I've rendered two images, one interior, and one not. The interior scene saw no speed-ups, at least in this scene, from adaptive sampling. However the robot render went from 4 minutes @ 4k resolution and 4k samples on PT, to 1 minute and 20 seconds with AS on.
rodross wrote:Thanks Ahmet for the hard work. Here's an example of the fruits of your labor.
I believe that you can exploit benefits of it for second scene. It needs some mastering to find a balance on parameters and noise distribution.
zinogino
Just tried it and noticed the LV is quite slow compared to last test.
But nevertheless, awesome
zinogino wrote:Just tried it and noticed the LV is quite slow compared to last test.
What is slow on you?
zinogino
Does it matter if the standalone version is not the same with the plugin?
no if you just use plugin.
