..frozen max on changing to z-depth on octanerender viewport.. repeated again on one pc, but works ok on another..
- so just scroll through those from time to time
OctaneRender® for 3ds max® v3.03.4 - 4.22 [OBSOLETE]
3dmax, zbrush, UE
//Behance profile //BOONAR
- Dmitry Lebedeff
- Contact:
???????????????????????????????where the version without error????????????????????????????????????????
this version crashes when i use material converter tool
- paride4331
Hi Jorgensen,
previously cheked issue.
Just sent to developers.
Paride
Paride
- richardyarlett
There is a big bug with this release. If you try to use the "TEXTURE ENVIRONMENT" texture in mtl editor it crashes the whole 3dsmax session.
I tried to drag my environment into the mtl editor and it crashes straight away. This was working fine in 4.21
- paride4331
Hi all,
in reference to the post:
viewtopic.php?f=80&t=57079&start=20#p293499
I do not know if this Envrironment slot material issue is related to the plugin version.
Could you tell me your gpu used and nvidia drivers?
Did you change GPU between 4:21 and 4:22?
Regards
Paride
Regards
Paride
- richardyarlett
It must be related to the plugin version. I have tested in on three machines and they all DO NOT crash with version 4.21 and ALL CRASH INSTANTLY when trying to access the "Texture Environment" in the material editor, in 4.22.
Even when uninstalling and rolling back to 4.21, it immediately works again.
I always use the latest NVIDIA drivers and I am using 3dsmax 2017 with Geforce Titans
- paride4331
Hi richardyarlett,
thanks for your reports and tests about this issue. It is sure to be in 4.22.
Developers are working to resolve the reported issue:
//4.23
//-fixed new crash from 4.22 in material conversion.
Regards
Paride
//4.23
Regards
Paride
- richardyarlett
I just tried 4.25 LATEST and this issue is still there. Crashed immediately.
