GTX 1080 Octanebench?
smicha
Chriz wrote:Yes i am just comparing rendering a scene with or without the 1080 ... :?
1080 renders the bench scene in PT at 32ms/s while 780 at 16-18ms/s so this is almos 2x faster.
glimpse
honestly, I'm really waiting for new build of OctaneRender..- hopefully some optimizations will fix some issues for some users.
Chriz
@smicha
Yes, that is how it is supposed to be :D
And for some reason that is not what i get at the moment. It is a miracle, but i will try everything to get it working right.
@glimpse
I would love to get some new features that are discussed in this forum a lot. But i don´t want to hijack this 1080 threat for that ;)
http://www.C9W.de - Win10 - Dual E5 2620v3 - Display 1 GTX 1080 / Render 1 3090 RTX - 96 RAM - C4D MSA - C4D Plugin version: current - Standalone: current
desire
smicha wrote: 1080 is almost 60-100% faster at OC than 780 - don't look at benchmark but measure speed in PT kernel for the same scene with parallel and tile samples set to max
thank you for your comment, smicha
I did right that way - parallel and tile samples at max, one scene, identical parameters in PT kernel. And the same (main) PCI slot on the motherboard.
780 gives 7 minutes 01 sec
1080 gives 6 minutes 03 sec
ps.> octane 3.05.3
the same scene rendered:
780+780 - 4 minutes 00s
1080+780 - 3 minutes 11s
smicha
ps.> octane 3.05.3
What are core and memory clocks for 1080 when you render - look at MSI Afterburner.
desire
under load
core - 1987
memory - 1128
smicha
desire wrote:under load
core - 1987
memory - 1128
Memory - do you mean 4x1128? 4500mhz?
desire
smicha wrote:Memory - do you mean 4x1128? 4500mhz?
i'm like nub in tech specs ((
here is screenshot https://yadi.sk/i/TK0zg3wH3DoaWs
smicha
install msi ab and set memory clock to 5000mhz, core clock at boost to 2000mhz. Send screenshot from octane gpus settings
desire
smicha wrote: install msi ab and set memory clock to 5000mhz, core clock at boost to 2000mhz. Send screenshot from octane gpus settings
Thank you, I'll try in a few hours and post result here
