OctaneRender™ 3.0 for LightWave™ - Alpha build 3.00.10.0
Lewis
I've installed 3.0.6 beta and rendered frame in 3h 23m 20sec, same frame that crashed 3 times today on 3.0.10 Beta.
So it's not my hardware issue then (a relief).
Maybe OTOY devs can answer me Is there anything on the 3.0.10 that requires newer Nvidia drivers than my current 359.00 ?
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
LightwaveGuru
Lewis wrote:I've installed 3.0.6 beta and rendered frame in 3h 23m 20sec, same frame that crashed 3 times today on 3.0.10 Beta.
Last Driver is 365.10. I use them and alpha 3.0010.0 is absolut stable. no bluescreens. no problems.
snip lwguru
http://www.neotek.laboratories.de or http://www.youtube.com/c/Lightwaveguru or http://www.facebook.com/safarifx 4x Titan X 12 GB watercooled / 6x 2080 ti air cooled / 2x 980 ti watercooled
BorisGoreta
When loading new surface IPR does not refresh ( long term issue )
juanjgon
BorisGoreta wrote:When loading new surface IPR does not refresh ( long term issue )
Yes, I remember it. I think that the problems was that LightWave doesn't report a surface change event, but I will check it again.
Lewis
snip lwguru
I'm also on 365.10 now but no difference
Do you have any GPU on PCI-E 1x extenders and what's your tonemap settings in plugin options.
My 3.0.6 stable as rock for 10+ hours, 3.0.10 crashes, quits rendering or blue screens.
Lewis
Skype - lewis3d
ICQ - 7128177
LightwaveGuru
snip lwguru
hi Lewis,
tonmap option is activated. And yes i have a extender installed...
you can see it here...
https://www.youtube.com/watch?v=B6k2bpXJKbY
https://www.youtube.com/watch?v=52Noo6yVZaM
snip lwguru
Lewis
Ahh but you have 16x PCI-E extender. i use 1x
Lewis
Skype - lewis3d
ICQ - 7128177
stef
I have less bug & freeze with these keys : TdrLevel 3 / TdrDelay 60
https://msdn.microsoft.com/en-us/librar ... s.85).aspx
With SLI unable, POWER max, all last DRIVERS,
http://driver-booster-free.fr.softonic.com (if you know best & free ??)
& Good air flow in the office ! :D
Big up to the team !
Have a nice day.
_
jang2235
Lewis wrote:Ahh but you have 16x PCI-E extender. i use 1x
I also suffered a similar problem.
The cause of the problem is found. Using PCI extension cable was the problem. The problem is slow PCI as doeneungeot. In response to so much data transfer and system memory over it so. Rig systems have a very disadvantage. It uses a PCI-E 2.0 X1 cable is currently being used to connect directly to the motherboard. An error has disappeared like a lie.
Lewis
It's not PCI-E connector/cable in my case 'coz Octane 2.25 and 3.0.6 works no problem with same setup while 3.0.10 crashes. If is cable it would crash same at least in 3.0.6 if not 2.25 which has different way for working but still stable in days of rendering.
Will test with new update and see how it goes next.
Lewis
Skype - lewis3d
ICQ - 7128177
Return to “Lightwave 3D”
