OctaneRender® beta 2.43 (lin/mac/win) [OBSOLETE]
GeoPappas
It is nice to see an update with fixes to some of the many issues that people are having, but it would be nice if you would take a look at the fixes that I have proposed in the following thread:
http://refractivesoftware.com/forum/vie ... =33&t=5125
Many of these fixes should be relatively easy to fix, would make the UI experience more pleasant, and would increase productivity.
abstrax
GeoPappas wrote:It is nice to see an update with fixes to some of the many issues that people are having, but it would be nice if you would take a look at the fixes that I have proposed in the following thread:
Well, when it comes to workflow there is always stuff to be improved. So, don't worry, we will fix/improve those issues, too, at some point. All the recent releases were mainly aimed at stability and all other changes were just additional things we could sneak in. But there is only so much you can do of those "small" changes in a limited time.
By the way - the resolution problem is not easy to fix unfortunately, otherwise we would have done it already. Please use the presets as much as possible. And now, you can also swap between different presets by just reconnecting the render target with different resolution nodes.
Marcus
kubo
oh boy, another day and a new present, xmas is a month old and my birthday is far away, and yet..
Thanks a lot :D
okichkoatl
hi, i have a problem rendering animations. i hit render button from blender, popups Octane then i setup my scene in Octane and Save it. then i setup my settings in blender for animations, i hit renderanimation button and starts to render the problem is that All nodes are disconected so, it doesnt respect my setup. plase some help. i need to render some animations.
best Regards
abstrax
okichkoatl wrote:hi, i have a problem rendering animations. i hit render button from blender, popups Octane then i setup my scene in Octane and Save it. then i setup my settings in blender for animations, i hit renderanimation button and starts to render the problem is that All nodes are disconected so, it doesnt respect my setup. plase some help. i need to render some animations.
best Regards
Hmm, I can't reproduce the problem here, but I'm using C4D and the C4D exporter. Do the material names change? Could you please give more details and post some screenshots? Maybe one of the Blender users can help you, too.
Marcus
carbon
abstrax wrote:
carbon wrote:ehm, alpha material crash in big resolution after about 1 minute of rendering, see attached scene, just select material. it is reproducible. on ubuntu 10.04, GTX 460, cuda 3.2, driver 260.19.26.
carbon@c14:~/Desktop/OctaneRender_COM_intermediate_pre243_linux_x64_cuda32$ ./octane
Releasing cuda context on thread 238475008
Activating cuda context on thread 219567872
Releasing cuda context on thread 219567872
Activating cuda context on thread 238475008
Cuda error in file '/home/abstrax/dev/cuda32/Octane_Project/src/renderer/cuda/octane_cuda_kernel.cu' in line 551 : the launch timed out and was terminated.
ERROR: Program executed illegal instruction.. terminating
Ok, the problem is each render pass at 4Kx4K resolution takes too long: On my GTX 470 each pass takes 5-6 seconds and according to the NVIDIA CUDA forum there seems to be a 5 second timeout in the Xserver. I don't know how to change that.
Is the GTX 460 used by your X server? Maybe you can run the X server only on your GTX 260. This might help.
If nothing helps, try it with 2Kx2K resolution, which should take less than 5 seconds on your GTX 460.
Marcus
sorry, my signature contains 2 machines, i should change it to be more clear. i work on mac os x and render on linux box which have just one 460 which is connected to display
http://www.x.org/archive/X11R7.5/doc/ma ... ver.1.html
-to seconds
    sets default connection timeout in seconds.
will this help (if i find where to put it :) )
or should i buy some cheap card for display?
thanks
c.
OSX10.6, GTX260(896MB), QuadCore@3GHz, 8GB RAM || Ubuntu10.04, 8400(display),GTX460(2GB), QuadCore@3GHz, 4GB RAM
steveps3
best Regards
Have you unchecked the option to overwrite the OCS file?
(OS) Windows 7(64)
PeterCGS
Sweet! First night ever I wasn't greeted with the activation screen after running some animation renders :) Also a nasty bug seemed to freeze Octane sometimes (happened also as frequent as the activation dropped), seems to be gone... Nice work on this release sofar :P
Win7, i7 980 Hexacore, 24GB RAM, 3xEVGA SC 670 GTX 4GB
Method
Thank you!
ASUS P6X58D-E / Nvidia GeForce GTX 780 / 24GB Ram (DDR3) / i7 950 (OC4.2Ghz-without HT) / Windows 7 x64 / and million cooling fans :)
VFX/CGI, Animation for documentary movies, Music videos, Products renderings, Advertising....3D/2D (small production)
teecee2107
Thanks for this release. It seems to work great !
