Version 2.23.1 - RC4 (Updated on 07.05.15)
Weirdpictures
Hello Ahmet,
nice work on releasing this version so fast. Over all it seem stop perform much better than 2.22, we just noticed that the great render layer functionality seems to be not working anymore. We used the function heavily with 2.22 on our latest project an just wanted to render some comparisons with 2.23.1, but noticed that none of our render layer masks are coming across.
Could that be related to the alpha material bug? Everything shows up correct within LV and we can see the mask working and generating the desired passes, but once we render to Picture viewer and select the usual render layer mask buttons all masks render rot black.
Any idea?
Weirdpictures wrote:Hello Ahmet,
Any idea?
would be great to get a sample scene for issue
Weirdpictures
Thanks Ahmet,
here is the test file. Trying to get object mask 2 + 3 to render. Its the window frame and centre top light.
Boardroom test.zip
Test file Render masks
(12.81 MiB) Downloaded 319 times
Weirdpictures wrote:Thanks Ahmet,
Boardroom test.zip
I think this should not work on neither versions of plugin. Because you setted the render method as "Send all scene data". This option is causing to loose all assigned object tag functionality.
Weirdpictures
Hey Ahmet,
thanks for quick reply. We did not know that send all scene data erases all objects. Sometimes we are using send all scene data in order to get a still shot without any motion to render multiple frames with different grain, otherwise Octane renders one frame in a non changing animation and then just copies the file after 2 frames. Is there any other way to force octane to render every frame in a still animation, so that we can use it with moving grain?
Weirdpictures wrote:Hey Ahmet,
Pfff.. You missed the all worklow logic of plugin. We have a bunch of new tutorials about secrets and usages of plugin. It's far better than lot of explanations. Please see them on first page...
cfrank78
Node Editor not working anymore. As soon as you change something like "transform" it crashes!
sdanaher
Problem: Activation is lost during overnight render.
Not sure if my Mac went to sleep during rendering as I had a load of frames saved without any render progress. In the morning I couldn't render at all: no devices because no activation.
At least it fixes the sleep/activation crash.
Edit: couldn't even reactivate with my user/password. Had to for quit Cinema and relaunch.
[OSX 10.10.3 - Cinema R16 - GFX Titan 12GB & 980 4GB - Octane 2.23.1 RC2 - (Standalone 2.23)]
Windows 10 - 64GB RAM - Cinema 4D R20 - RTX 2070 x3
cfrank78 wrote:Node Editor not working anymore. As soon as you change something like "transform" it crashes!
Hi Chris,
can you give me sample? It's working well on me.
sdanaher wrote:Problem: Activation is lost during overnight render.
It may be a hw problem on your computer. Try deactivate/reactivate.
