Hi guys,
Finally I started with actually building the CoolBox.
The AC (AirConditioner) is on the wall and ready for its job.
The design has changed little bit and I will make triple sliding glas panels on both sides like this:
Now the next phase starts building the black 'table', white 'frame' and 'glass'.
I have done the thought exercise of climate, and I already got some good replies in this thread earlier,
but I got confused (and unsure) again... grumble
.. it is about humidity and temps (air of space, air blown by AC and air inside PC)
To avoid damage to the PC (parts) by ESD (electro Static Discharge) the higher humidity is better.
Normal humidity isabout 50-70%. So 65%-70% is a good climate goal.
To avoid condensation a lower humidity is better.
So here we go!?
Now I have found this vid... with AC directly blowing the cold air into the PC.
and Ramone (posted the vid) stated that "As for Condensation???
WONT HAPPEN!!!"
https://www.youtube.com/watch?v=Wf9N7qpwiO0This guy wrote a whole explanantion of how and why.. very interesting
,but all dazzles me to really understand.
I found this graphic of temperature and humidity and I tried to project a glass of beer (condens on it)
and the PC with cold air blown into it (from above).
Let's assume the temps of PC is 40 and the air blown into the PC is 10 degrees
the air blown into the PC must be very dry and below 20% not to cause condensation.
Do you think this reasoning is correct?
Why all this? Well, I try to figure out the risk of condensation of using the AC with my PC's?
My guts say it will not condensate when not setting the AC goal-temp lower then 20 celcius) like in the working space.
It won't condensate inside my PC when having the window (nearby PC) open and having cold wind blown inside, would it?
But my devil on shoulder says otherwise... grrr.
Someone has a good thought about this?
cheers,
