Is poly limit fixed?
is poly limit fixed?
I ask 3 times because I never seem to get a response when I ask. I bought v2 last year and still I am using V1 because I have high poly scenes. If it is not fixed I think a refund is in order because nowhere did it say when I upgraded that my old scenes would not open in V2.
Sorry to be blunt but it's been 7 months and I cannot use it for the purpose I bought it for.
Even some sort of acknowledgement would help, are you working on this? Will it be fixed, is it low priority for you guys?
OctaneRender® for 3ds max® v2.20
Hi Karba,
Does the multi uv channels feature could help us to provide W mapping for the hairs (in the future)? Or is it completely diffferent thing?
My Portfolio
- gabrielefx
Hi Karba,
many issues in Vray translator found:
Please load the scene #8 of Archinteriors 27. Many planar lights aren't converted and some Vraymtls.
I tried with some old Vray scenes too. Some materials and lights aren't converted. With 1.18 is ok.
Octane issue:
If I load a scene created in Octane for Max 1.18 into Octane for Max 2.2 the planar lights that were invisible now are visible also if the visible option is off.
Octane for Rhino VS Octane for Max:
I don't understand why in Octane for Rhino I got the stereoscopic option. I can render side by side frames.
I need this option implemented in Max.
regards.
Octane issue:
regards.
Gabriele I noticed that error.
I must say. I didn't test this thoroughly But.
- It seems like translator has problems converting especially lights if they are in nested groups. (I mean groups in groups)
Ungrouping worked for me not all but in some cases.
- Also multiple clicking on the convert button sometimes works as well. In every click on the translator, another light is converted. Also there might be an issue where Vray lights in the scene are instanced.
You can try to make the instanced lights unique. Than instance them again by using scripts.
I might work for now.
And there is the visiblility problem as you mentioned.
As I said I'm not %100 sure of these. Hope it helps.
My Portfolio
- gabrielefx
Hi Karba and Oguzbir
Octane for Max 1.18 translates perfectly that Vray scene.
Octane for Max 2.2 failed.
Tried now 1.18 with scene #8 Archinteriors 27
all lights and materials are translated as expected (except some vray special materials not adapted yet)
