smicha wrote:I'll be precise as I can:
1. Power: for each Titan Z you need 600W (Octane will draw no more than 400W). So for 6 Titans Z you need 3600W (Octane will draw 2400W), for 8 - 4800W (Octane will draw 3200W). If you have 3x1600W you can run safely 8 Titans Z, including spikes. I would connect 3 Titans Z to first 1600W PSU, next 3 Titans Z to the second PSU, next 2 Titans Z and the rest of the components to the third PSU.
2. Radiators: External rads are the must in this case. For 6 Titans Z you need about 14-16 radiator units (120 or 140mm), for 8 Titans Z - 20-24. So Aquacomouter 3360 Gigant is made for you with 24 units, each for a 140mm fan.
http://shop.aquacomputer.de/index.php?cPath=7_31_2026
3. Fans for radiator: this may sound strange but lots of guys say Noctua is the right choice - I am not one of them. Actually I am selling Noctuas - they are loud when set to 1500RPM compared to be-quiet fans or SanyDenki fans. These fans are so well built compared to Noctua
http://www2.mouser.com/ProductDetail/Sa ... z90w%3D%3D
but expensive. Currently I am testing SanyoDenki 2200RPM and it literally blows Noctua. But 2200 RPM is way too much so I am looking at 1500-1800 RPM fans to operate silently at 5V. So if you want to go with SanyoDenki 24fans x 60USD = 1440$. Then also get Lamptron fan controller for 30W per channel input.
I have 4x140 be quiet fans and - I love them - they are so quiet and efficient. I have them set at full speed all the time and I don't hear them (opposed to loud noctua at 1500RPM). So the second choice (IMO) is
http://www.bequiet.com/en/casefans/260 - you will hear silence. Literally.
But these two differ in terms of:
A. Static pressure - there is no better fan out there than SanyoDenki (5.3 mmH2O) which is a monster at 1900 RPM. Be-quiet pressure is 0.81 mmh2o at 1000RPM. So if you have hot summers get SanyoDenki and set them at low speed for regular usage.
B. BE quiet is beautifully sleeved and comes with rubber mounts. The drawback of the SanyDenki fans - you have to apply 3pin connectors on your own - they come with no box, bare cables. But you don't pay for a box and cables (as Noctua) but for the greatest quality fan.
4. Get double dual tops (EK as an example) and connect 4x D5 pumps.
5. Then use parallel connectors between water blocks. With 4 D5 pumps you'll have great water pressure to split even between 8 Titans Z. I my setup the parallel bridge gives 1C temp difference on consecutive cards.
Thanks Smicha for all of that most useful advice. You've really got me to think more deeply about my computer system needs and priorities. Your advice/formula for power requirements has already led me wisely forgo purchasing a 7th or 8th Titan Z, and thus also make way for serving my 4k video productionsneeds with the Revo 350s, GT640 and SATA drive backup. That Aquacomputer 3360 Gigant is a monster of an external rad. I'm sure that it's a magnificent cooling component. Your pointing out the various water cooling consideration for my computer made me also think about serving my human water cooling requirements. I'm considering purchasing a small refrigerator for this computer room. Of the two refrigerators that I'm considering, each is extraordinarily quiet, consumes just 83 watts and can be adjusted within the temperature range of 36ºF - 56ºF temperature range. Their only significant difference is size and cost. Here are fuller specs:
(1) Avanti 1.7 Cu. Ft. Superconductor Refrigerator - Stainless Steel
Model:SHP1702SS
Price:$89.97 US
Brand: Avanti Solid state components for reliability
No vibration
Adjustable thermostat
Auto Defrost
Environmentally friendly
Soft interior LED light that operates when the door is open
Reversible door swing
Tall bottle door rack - holds a 2 liter bottle
Slide-out shelf with three positions
Shipping weight: 31 pounds; net weight: 27 pounds
No compressor step- no compressor!
Power: 83 watts, 115V, 1.1 amps
Warranty: One year parts and labor
Dimensions: 20.5" H x 17" W x 18.75" D
or
(2) Avanti 2.5 Cu. Ft. Superconductor Refrigerator - Black
Model: SHP2501
Price:$125.97 US
No vibration
Auto Defrost
No compressor step
Shipping weight: 45 pounds; net weight: 40 pounds
Dimensions: 29 1/2" H x 17" W x 20 1/2" D
I can also set the reservoir on top of either of them to increase liquid/head pressure to my computer system, which will I'll set closer to the floor.
Do you recommend PrimoChill or another brand of non-conductive coolant or are there other coolant related considerations that I should take into account? Should I also use separate leak detection and temperature and pressure sensors and, if so, what brand(s) and model(s) do you recommend?
