***** NEW ICON SET DESIGN ***
Hi all i'm posting again because it was losted on previous page,
there is a preview version before doing a release. Please see the improvements and drop some notes here.
Octane dialog and Lv have "Gui" menu to able show/hide menu and icons. You should close and reopen the windows.
Also check shift+F12 to see new "Octane ........" commands. You can place them to anywhere.
2.12.2-test2 Windows version (R13-R16)
http://render.otoy.com/customerdownload ... t2-win.zip
2.12.2-test2 MacOsX version (R14-R15)
http://render.otoy.com/customerdownload ... Macosx.zip
milanm
I just tried test release. This is fantastic!
It's now possible to create Octane lights using shift+c menu. Very useful.
BUT keyboard shortcuts only seem to work for Octane Dialog and Octane Settings now.
Maybe type should be Command instead of Hotkey?
Also lock resolution seem to reset after resending the scene. I have to resize the window a little for it to work.
I tried this on both Mac and Windows and it works the same here.
Thanks!
Regards
Milan
Colorist / VFX artist / Motion Designer
macOS - Windows 7 - Cinema 4D R19.068 - GTX1070TI - GTX780
pBarrelas
Sorry aoktar but no luck here. The GUI menu doesn't work at all here.
Win 8.1 Pro 64-bit| i7-4930k 3.4GHz | 32 Gb RAM | GTX 980 4Gb| Driver Version 344.75
milanm
pBarrelas you have to close and reopen LV window to see the change, did you try that?
pBarrelas
milanm wrote:pBarrelas you have to close and reopen LV window to see the change, did you try that?
Yes, I did it several times! No luck!
I have updated command parameters for shortcuts. try to re-download again.
pBarrelas, wait a little to see other feedbacks. I have checked a few times, but everythings ok on me. Let's check again tomorrow.
milanm
aoktar wrote:I have updated command parameters for shortcuts. try to re-download again.
I downloaded again and yes, keyboard shortcuts are working now! Finally!
Ahmet you are amazing. Thank you.
Regards
Milan
pBarrelas
Thanks! I'm feeling a bit frustrated, though! ;)
Iceman9
New GUI menu works here (Mac/R16) and I love it!
Only two outstanding issues for me:
-Geometry changes still don't refresh
-I don't know how to access keyboard shortcut key(s)... well to be specific... It's the Send your scene and restart render button that I wanted the keyboard shortcut for. Perhaps I wouldn't care if auto-refresh worked reliably, but it doesn't right now.
are you activating "geometry updates" in LV options menu? also assign a shortkey to "start octane render" command. we have checked it, no prob. how you can't get it worked?
